1974 DT125A Build/Restore
- torqueflight
Replied by torqueflight on topic 1974 DT125A Build/Restore
Took the carb and reeds to my friend that has an ultra sonic cleaner. Every hole was clogged.
One of the reeds is lifted up. It has nothing to do with the reed itself. The rubberizing on the reed block is uneven under the reed. Not sure how much of a head ache this is going to be.
You can see at the red arrow where its uneven.
03 May 2021 15:40
#41
- torqueflight
Need to get an o ring for the petcock arm. Also does anyone know if the filter by the reserve stem is supposed to come out? I tired like hell and couldnt get it out.
The carb and bowl after the clean. I also need an o ring where the carb goes into the bowl.
- torqueflight
Got the carb back on.
Might need some help at this part.
I used a jump pack on the battery, turned the key on and I have lights, turn signals and the e start cranks/works. Compression sounds good too.
I pulled the plug to see if there was spark and nothing. The ended up coming off. Anyone know if it can go back on or
do I need a new wire?
Also what on there needs to be cleaned to try and get spark?
03 May 2021 15:49
#43
- Schu
Replied by Schu on topic 1974 DT125A Build/Restore
Ok, I think I might pass next time my dentist offers to clean my bite guard in his ultrasonic cleaner.........
03 May 2021 15:50
#44
- torqueflight
Haha. They are grills, but the ultra sonic we used is for carb parts only.
03 May 2021 15:53
#45
- torqueflight
Nevermind,
Got her running off carb cleaner. Pulled every wire off the stator and sanded and contact cleaned.
Now to clean the tank.
03 May 2021 18:23
#46
- torqueflight
For the record that shift lever is incorrect for an e start bike.
14 May 2021 19:32
#47
- Mothersbaugh
Replied by Mothersbaugh on topic 1974 DT125A Build/Restore
I assume you meant the end came off? Mine comes off on a CT-2 I own, too. I just stuff it back on, and it runs just fine.
Someone else will help you on what to clean. I have five 125cc bikes, but they all start and run just fine, so I have not tried to fix them, since they are not broken.
14 May 2021 19:56
#48
Replied by MarkT on topic 1974 DT125A Build/Restore
I think he meant offset is incorrect... correct shifter is offset to clear the ignition cover.
14 May 2021 20:45
#49
- Mothersbaugh
If you are commenting on me, I was talking about the spark plug connection between the cap and the wire itself. But, yes, the shifter is more rounded and hangs outside the starter cover.
14 May 2021 20:49
#50
