1975 DT175 timing questions
Replied by Midlife Motor on topic 1975 DT175 timing questions
Here is a sneak preview. A condenser made for an older Jeep CJ. Lead wire from condenser allowed me to make a T splice set up by changing the wire end using Vintage Connections piece. I also made a jumper wire for grounding condenser. One end goes to side of condenser and the other end under the bolt which mounts the coil to the frame. New condenser is now under gas tank. 10 mile ride this morning showed good results so far. Time will tell.
The following user(s) Liked this Post: GJVGC
Last edit: 21 Jun 2020 11:02 by Midlife Motor.
21 Jun 2020 10:25 #171
  • GJVGC
  • GJVGC's Avatar Topic Author
Replied by GJVGC on topic 1975 DT175 timing questions
^ very cool.
So you soldered the 3 wires at the flywheel together and tucked them away?
The new condenser with the wire goes straight to the ignition coil and is also grounded.
21 Jun 2020 12:31 #172
Write up just posted
21 Jun 2020 13:08 #173
  • GJVGC
Just saw it.
Simple enough!
What year is the condenser off of?
21 Jun 2020 13:17 #174
Not sure, but here is what the box says for part number.
21 Jun 2020 13:28 #175
  • GJVGC
^ thank you
Also thanks for posting a write up on it.
Will be checking it to see how it goes after a few rides
21 Jun 2020 13:37 #176
  • GJVGC
Does anyone have a legible wiring diagram for the 1975 dt175 they could share?
I can’t see on the one in the site even when I zoom in.
22 Jun 2020 03:51 #177
Replied by Yammiedodger on topic 1975 DT175 timing questions
Hi buddy have a look on this site under the heading of wiring diagram in colour as I posted up a PDF on the 28th of May. It’s pretty good but may need a couple of mods on the brake light feeds, other than that it should work for you. If you need any pictures my bikes outside just now and I am at work so wouldn’t be a big deal for me to go and do a few snaps for you! good luck
22 Jun 2020 04:32 #178
  • GJVGC
^ thanks!
That’s a great color diagram!!
22 Jun 2020 06:12 #179
Replied by JimA on topic 1975 DT175 timing questions
I think I had posted this one in the same thread as Yammiedodger. Hope it helps.
Jim
The following user(s) Liked this Post: Yammiedodger
22 Jun 2020 22:33 #180
This message has an attachment file.
