1975 DT175 timing questions
Replied by Swoop56 on topic 1975 DT175 timing questions
I think your carb is correct . I just went and checked out DT 175 B carb page on
Rocky Mountain ATV , and the carb part number has a 443 prefix , which is the number stamped
on yours . the diagram shows main jet as a side entry too .
I don't know where you picked up your parts page , but it might be for a different market bike .
So carry on .
31 May 2020 20:03 #121
  • GJVGC
  • GJVGC's Avatar Topic Author
Replied by GJVGC on topic 1975 DT175 timing questions
Swoop,
I just noticed the same thing as I went to order the main jet etc.
That photo I posted earlier is from the service manual I downloaded from this forum.
It says dt175 A, b ,c With that diagram under it.
Thanks for the help!
31 May 2020 20:30 #122
Replied by MarkT on topic 1975 DT175 timing questions
Here is the factory service data sheet:
31 May 2020 20:38 #123
Also I found some stock reed petals and stoppers from a 175... and the whole assembly.
Just FYI you can also buy the whole assembly new from Yamaha (Partzilla) for $102. That's probably what I'd do.
31 May 2020 20:47 #124
Replied by Mothersbaugh on topic 1975 DT175 timing questions
I'll add that I started out a few years ago doing these Mikunis, and last summer, I rebuilt a 1997 XT350 carb. Both sides of it. And it fired right up second kick! And ran perfectly. If I can do it, you can do it.
Last edit: 31 May 2020 21:07 by Mothersbaugh.
31 May 2020 21:04 #125
  • GJVGC
Giving it a shot. Thanks guys
Im putting it back together as it was with a new 160 main jet.
If this doesn’t fix it I will order the reeds from Yamaha.
01 Jun 2020 07:00 #126
Replied by Snglsmkr on topic 1975 DT175 timing questions
It may have been removed for the photo.
Was there a soft metal washer/gasket on the main jet banjo bolt?
01 Jun 2020 17:51 #127
  • GJVGC
^ yes there was a rubber gasket on it.
I still have it
Would it be ok to use a copper crush washer?
01 Jun 2020 18:07 #128
01 Jun 2020 22:08 #129
  • GJVGC
^thanks, ordered one.
I was able to get everything new oem except the float.
07 Jun 2020 06:46 #130
