yamaha 5LT Restoration
Replied by Rick C. on topic yamaha 5LT Restoration
T-Bone is correct. Old brake shoes can De laminate from the metal ( even when you think they are OK,)
and pitch you over the bars..Which is never any fun.
Get some shoes. Cheaper than a Hospital bill.
The following user(s) Liked this Post: MarkT, s900t8v
Last edit: 21 Jan 2020 21:00 by Rick C..
21 Jan 2020 20:51 #51
  • s900t8v
  • s900t8v's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Replied by s900t8v on topic yamaha 5LT Restoration
Ordered more parts and a few were in stock so I grabbed those!
1976 Yamaha AG175 cafe
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
21 Jan 2020 20:52 #52
  • s900t8v
  • Platinum Member
  • Platinum Member
Ok I’ll get some new brake shoes.
In the end I went with these 2.75 cos they were cheap.
the rear guard is a bit damaged so it’s a bit wider than it should be it does look a bit goofy. Ah well I’ll change to 3s at a later date I suppose.
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
21 Jan 2020 22:26 #53
Replied by Noviastar on topic yamaha 5LT Restoration
nice on the seat. I got a Double seat on the way. see how well it fits. I'm almost happy with mine in function. The carb slide spring is tired. no spring back on the throttle. so I'm looking for a spring there. Got a oil leak from the auto mix tank.
I look forward to hearing how yours is going!
22 Jan 2020 06:05 #54
  • s900t8v
  • Platinum Member
  • Platinum Member
There’s a spring in the throttle cable divider to oil pump as well you could put a stiffer one in there.
Most of the time it’s just crusty cables. I pull the cable out and then spray it with Teflon dry lube then solder a new nipple on. If the cable is rusty or liner is damaged i just make my own replacements.
You can always cut a coil off and stretch a tired spring to give it a higher spring rate.
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
22 Jan 2020 16:03 #55
Replied by apex on topic yamaha 5LT Restoration
The original Candy Yellow or Gold or whatever comes through so nice in your photos. I'm a sucker for candy colors so this little L5 is looking GREAT!! Nice work, love to see lights working as you showed in your photos!
Allrighty Then
The following user(s) Liked this Post: s900t8v
22 Jan 2020 19:32 #56
  • s900t8v
  • Platinum Member
  • Platinum Member
Thanks the paint is in pretty Bad shape.
When I get some time and funds I’ll respray it. I’ve sprayed a fair bit but never a candy colour. They are hard to do I’ll have to get a few test panels going.
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
23 Jan 2020 15:18 #57
  • s900t8v
  • Platinum Member
  • Platinum Member
hey guys
got no spark
I have 12v at ignition coil
the breaker wire to ignition coil is not open circuit
the breaker points open and close, measuring between the points I am getting 0.5 ohm and open circuit with closed and open points respectively.
I am thinkign I must have a dead coil, there is continuity from spark plug lead at coil to spark plug.
coil terminal resistance is 8k ohm,
what should it be? couldnt find it in the book..
also anyone got cheap source for good coil replacement
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
24 Jan 2020 20:46 #58
  • s900t8v
  • Platinum Member
  • Platinum Member
and after some more troubleshooting
it was corroded terminals on ignition coil and also corroded contact breaker points
sanded them up and got spark
then it basically started up straight away really easily!
lots and lots of smoke :D :D :D
idles nicely, dont think the crank seals are too bad.
Now to do all the small jobs putting bits and pieces on and getting it all back together!
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
The following user(s) Liked this Post: mdscott, JGersh
Last edit: 24 Jan 2020 22:06 by s900t8v.
24 Jan 2020 22:04 #59
Its alive! thats awesome. This bike might just run forever as long as gas and spark can get to it. I got some contact sanding to do myself. Bit to much resistance in the system and the electric start doesn't like to work and blows the main fuse.
Yikes might be a heavy smoker.
24 Jan 2020 22:44 #60
