74 dt125: First Attempt At A Restoration-resto mod.
  • 2fishkev
  • 2fishkev's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Curing the paint. Waiting for dry pavement
The following user(s) Liked this Post: Badger52, Schu, JHof44
Last edit: 28 Mar 2020 13:25 by 2fishkev.
28 Mar 2020 12:44 #31
Replied by the bobster on topic 74 dt125: First Attempt At A Restoration-resto mod.
Do you recall the initial carb screw settings? Air screw is 1.5 out but I dont know the idle screw setting. I have the 1975 version of this bike.
16 Apr 2020 20:19 #32
  • 2fishkev
  • Platinum Member
  • Platinum Member
Not so much of a setting there as in 1.5 turns, etc. that screw contacts the slide, so it’s variable. The manual specifies 1300-1400 rpm if I remember correctly. I’m just on the coffee now. Good luck!
17 Apr 2020 05:47 #33
Awesome build!! I’m hoping to do something similar and restore my 125. Was also wondering what tires you’re running on it
Sent from my iPhone using Tapatalk Pro
19 May 2020 09:00 #34
Looks really good from here. :likey
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
19 May 2020 16:13 #35
  • 2fishkev
  • Platinum Member
  • Platinum Member
Many thanks Md! Just shows what this forum can make possible. It sure is fun. Good thing too because the other 3 don’t run yet!
19 May 2020 19:06 #36
  • 2fishkev
  • Platinum Member
  • Platinum Member
Thanks! It was a first time project for me. It’s whats possible with the knowledge gained here. And money. Lotsa nickels and dimes. For tires, I just put Shinko 241s on it. Probably the most inexpensive tire available for these. 2.75x19 and 3.50x18.
The following user(s) Liked this Post: Anytizer89
19 May 2020 19:12 #37
Awesome! Thank you! I’ve been looking for tires for about a week and wasn’t sure what would fit on it
19 May 2020 21:36 #38
  • 2fishkev
  • Platinum Member
  • Platinum Member
Just for shitsngiggles I replaced the positive side battery wire today with a well made replacement and for once the electric start worked first try on a cold motor. Well, as cold as it’s going to be in the high 80s. But replacing that 46 year old wire, one of few left, I believe made a difference.
It’s mostly been just riding this one for the last 2 years and fixing little things. The front fork rebound is getting notchy (?), so I’m going to try changing the oil, but I don’t think that’s it. Not sure what it is though.
Noticed yesterday that I’d thrown a sprocket bolt on my rear hub. Had to snatch one from the next bike in line and retorque all the others. That seems to be this seasons lesson. I need to check bolts and nuts for proper torque as I’ve had things come loose from time to time. The head nuts are the worst offenders.
17 Jul 2020 18:56 #39
Thanks for even more motivation for me - I've been working on mine little by little and just about gave up on it, but the new member Hondarider on here is rebuilding the engine. Looking forward to getting it rolling!
Barry
KK4RXN
Jeremiah 29:11-13 / John 3:16
19 Jul 2020 15:20 #40
