74 dt125: First Attempt At A Restoration-resto mod.
- 2fishkev
74 dt125: First Attempt At A Restoration-resto mod. was created by 2fishkev
I've been a member for about 2 years, mostly reading and researching. Ive been slowly restoring and gathering parts for reassembly. -And buying special tools. Every process has been a first for me motorcycle and restoration-wise. I'm relacing and truing rims now, which the reason for the first post.
Does anyone know the spoke wrench size needed? The smallest I have is 5.4 and it feels looser than I would like. Also what are the rim offsets?I didn't realize I needed to record that before I had to cut the rims apart.(corrosion) Those 2 bits of information have eluded me online and in 2 manuals. I would appreciate any help given. I could never have undertaken this pre-internets.
Obligatory photo, better to follow.aa
The following user(s) Liked this Post: James Hart
14 Jun 2016 09:20
- 2fishkev
Replied by 2fishkev on topic 74 dt125: First Attempt At A Restoration-resto mod.
Success Today! Started 74 dt125a restoration 4 yrs ago with tear down and 2nd over piston/reborn/rings. Sand blasting, sanding, filing, powder coating, painting later with many small parts left to do in near future.
Today I refitted inlet fitting into spark plug whole instead of center of block off plate, yamabonded every thing and held 5.75 psi for 15 min. and 7 in. vacuum for 2 min. Thank you to everyone who's shared their knowledge, especially the expertly documented restorations and work by the senior Enduroholics.
29 Jul 2016 16:34
- 2fishkev
Wow. Sorry GFrench for reposting your pic. Must have saved it for reference to build my leak down tester. The spotless frame and seat cover along with the bench was the give away. My apologies once again.
29 Jul 2016 16:42
- yorarider
- Content Contributor
Replied by yorarider on topic 74 dt125: First Attempt At A Restoration-resto mod.
Glad you clarified that, I saw that 2nd to last pic and thought, what the hell he gained 235cc's and became a piston port. That would have been quite a trick
"Whether you think you can or you think you can't, you're right"
- Henry Ford
Or in the words of Yoda... "Do or do not. There is no try"
"Don't believe every quote you read on the internet"
- Abraham Lincoln
- Henry Ford
- Abraham Lincoln
29 Jul 2016 16:56
- 2fishkev
My forum-fu parallels my rebuild skills. Ha ha. Today it was engine tests and direct posting from iPad for first time. All in all it came out well. Order tire spoons and next week I got my first roller!
29 Jul 2016 18:01
- yorarider
Look great! I like the caribou on the shop wall as well. My wife threatened to make me put all my mounts on in the garage, so I bought 80 acres and built a cabin for all my mounts... she's not invited to come up to the cabin
It keeps us both happy.
- Henry Ford
- Abraham Lincoln
- Henry Ford
- Abraham Lincoln
29 Jul 2016 19:17
- 2fishkev
I got a 10 ft ceiling instead of 8 ft for that reason and canoe/kayaks. My wife tolerated it until the day I got the inside finished and heated. Might have to work the 80 acre/cabin angle some day though.......
29 Jul 2016 19:37
- 2fishkev
Today I installed the engine in her frame after cleaning tabs down to bare metal. After looking at the manual and two searches here, I'm still wondering what other spots on the framework, etc, are grounding points? Handle bars, brake switch bracket, indicator light brackets? Any info would be appreciated and save a lot of time and frustration in first restoration. Thanks.
12 Sep 2016 15:15
- 2fishkev
It's been a while since I've posted and a while since I've gotten anything done , but I'm finally getting somewhere. Got the motor in the frame and fenders on. The front one is off a 70 or 71 Ct 175. Alloy(?) with rivets. When I test-fitted the front fender, I didn't like the way it was cocked up in front. Yesterday while final fitting it, I noticed the rear bracket was tweaked. "Hmmm, maybe a bend down here and a bend up here, see what that does". It's just about perfect now. It's surprising how parts get so tweaked in 40 years. The fun is unraveling the many mysteries and assembling a bike that looks straight. Hopefully.
14 Sep 2017 02:55
- 2fishkev
Here’s a minor update. In 4 months I’ve had gauges, wiring harness, and oil pump remanufactured by DEET and installed. Thanks again DEET. I finally completed the plating of all fasteners and installed all components that have been waiting patiently. Got outer cases wet sanded, polished, and waxed. Glad that’s done! Set timing and installed the cases tonight. Once I finish odds and ends up, I’ll be able to do the final assembly. I’ll use some extra ‘75 tanks for the first startup. It’s been apart 6 years now, so will have a variety of questions. I do have the shop manual, Clymer, and parts list but not every assembly question can be tracked down. I also have a parts bike and another parts bike to make the first parts bike whole, but they’re missing or apart just enough to not be any help most times. Ha ha!
01 Mar 2018 18:06
