Oil pump missing pin
  • Jimbobaroobob
  • Jimbobaroobob's Avatar Topic Author
Oil pump missing pin was created by Jimbobaroobob
Hi all, DT3 oil pump question. Please see photo, at some point the pump was deactivated by removing the pin that the pulley cam rides against- I’ve placed a nail in the hole just to keep it in place. I’m thinking of using a 2mm roll pin but was it originally a solid/ taper pin?
TIA
James
18 Jun 2026 12:28 #1
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Replied by RT325 on topic Oil pump missing pin
Was originally a roll pin. Might be lying under the pump or in the cover if lucky. If so then fit it the other way around so fractionally tighter. Big thing is don't insert it too far until it stops the pump shaft rising & falling. Fine line between to far & just enough.
The following user(s) Liked this Post: MarkT, Jimbobaroobob
18 Jun 2026 14:53 #2
Replied by Swoop56 on topic Oil pump missing pin
Yamaha part number for the roll pin is 91608-20010
The following user(s) Liked this Post: MarkT, RT325, Jimbobaroobob
18 Jun 2026 18:20 #3
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Some models in later years had a right angle plate mounted under the little nut so it covered the pin & moved up & down--ok in & out--with the stroke so constantly closely covering the roll pin incase it went into escape mode as yours did.
Here's a link that shows the plate in place if link works.
hvccycle.net/yamaha-oil-injection-pump-r...hvc200103/#gallery-1
The following user(s) Liked this Post: MarkT, Snglsmkr, Jimbobaroobob
Last edit: 19 Jun 2026 17:11 by RT325.
19 Jun 2026 17:03 #4
  • Jimbobaroobob
Replied by Jimbobaroobob on topic Oil pump missing pin
Thanks all, much appreciated. I think the pin was removed in a previous life as part of deactivating the pump for premix. I’ve tested the pump and all seems good so will get a pin ordered. Thanks again.
21 Jun 2026 12:55 #5
