Thermal Flow Shock Rebuild
- Le7316
Replied by Le7316 on topic Thermal Flow Shock Rebuild
Thank you !
14 Sep 2022 07:00
#61
Replied by RT325 on topic Thermal Flow Shock Rebuild
Gosh, lot of skilful work been going on there. Good to see all the pics.
The following user(s) Liked this Post: Le7316
14 Sep 2022 19:25
#62
- RTD2
Replied by RTD2 on topic Thermal Flow Shock Rebuild
For what it's worth, the 28mm two seal stack in my shocks give me dampening, but I do not have them on the bike under load yet so I will not know if they blow under pressure until I get my 73 MX360 done and that will take a while. So far so good, but absolutely no guarantees yet.
Mike
Mike
15 Sep 2022 18:56
#63
- Le7316
I'm sure it'll be fine ...
The following user(s) Liked this Post: RTD2
16 Sep 2022 13:16
#64
- Le7316
The rebuild is finally done . These 75 DT250 shocks not only made the rear more aggressive and beefy on my LT2 but there is a huge improvement in the damping. I only own this bike for almost two months but man I love this bike even more after a few part replacement ( front Yamaha sprocket + seal , rear JT sprocket and the Takasago Chain - Made in Japan ??) . I also have an extra exhaust tip laying around in my garage but it was little too long so had to cut it and drilled a new hole …Anyways , always thought the stock exhaust looks kinda naked w/o it ?.
photos.app.goo.gl/PVFSUwe6RgyZKVdk9
- jeffjeffjeff
Replied by jeffjeffjeff on topic Thermal Flow Shock Rebuild
Do you know how to figure out how much oil to add to these? Can't find it in the manual anywhere.
04 Nov 2022 12:07
#66
- Le7316
Add 175Cc ( 6.0 oz.) shock fluid to reservoir. Reservoir cap bolt is torqued to 175-200 in/lbs.
- automan
Replied by automan on topic Thermal Flow Shock Rebuild
Le, what brand pin spanner wrench was used?
cliff
cliff
05 Nov 2022 01:15
#68
- jeffjeffjeff
I made this tool out of a socket and a grinder. It's not pretty but it worked well with no slippage. The vertical cut to get it over the rod also served to place a crescent wrench to turn it. It worked well.
- RTD2
I bought this on Amazon:
Universal Black Finish Steel Adjustable Face Spanner Wrench Pin Pliers For Round Nuts with Drilled Holes (3mm)
I had to do a little grinding, but it worked.
14 Nov 2022 12:54
#70
