Thermal Flow Shock Rebuild
Replied by Ctune80 on topic Thermal Flow Shock Rebuild
Thanks for putting up some pics of the rebuild. Out of curiosity what is the shaft diameter on the thermal flow shocks?
The Ox is slow, but the Earth is patient.....
30 Oct 2019 16:17 #21
Replied by Wessi on topic Thermal Flow Shock Rebuild
Forgot the thickness of the bronze guide I made on my Lathe and can“t measure any more.
I chosed the thickness the way that bronze guide thickness plus oil shaft seal thickness exactly fit into the cap, not overlap.
This way, everything holds into place and is sealed after mounting.
Next step was sand blasting and powder coating the housing, mounting and fill with 175ml oil (10W).
Finally mount the springs and work is done. Damping seems to be ok. My bike restoration is not finished, yet, so I can not ride. Motor has to be repaired ....
The following user(s) Liked this Post: Steve F, MACE6772, Snglsmkr, Gr8uncleal, meadeam
Last edit: 31 Oct 2019 00:19 by Wessi.
30 Oct 2019 23:43 #22
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic Thermal Flow Shock Rebuild
Looks good!
31 Oct 2019 00:14 #23
Replied by PMK on topic Thermal Flow Shock Rebuild
FWIW, I made a call to Race Tech asking about sealheads for the Thermal Flow shocks. They do not have them.
31 Oct 2019 16:07 #24
Your bushing setup looks nice.
You might find though, the oem setup uses the steel disc, that is under the sealholder, is acting as the bushing that the shaft rides on.
31 Oct 2019 16:11 #25
Replied by Silo7 on topic Thermal Flow Shock Rebuild
12.5mm
12 Dec 2019 09:04 #26
Bought a Trick Kit for Thermal Flows. New Old Stock with instructions. Not sure if these have been discussed here or not. Be curious to see what differences , or changes they make to the shocks.
19 Jan 2020 04:22 #27
Replied by Tjlee on topic Thermal Flow Shock Rebuild
I am a new member restoring a 74 DT250. Found this site after researching information on the thermal flow shocks. Great information and thanks for posting!
The following user(s) Liked this Post: MarkT, mdscott, tricky
05 Apr 2020 18:40 #28
I have zero experience with these thermal phase shocks, so this is great help. I also read where someone has come up with a seal kit since this rebuild was posted, but I cannot find that thread again. Does anyone know of the seal kit and who to contact?
Restoring a bike is a lot of fun. These threads have been real helpful.
Tom
26 Apr 2020 08:19 #29
You can get proper seals here.
www.nthrepro.com/
26 Apr 2020 08:22 #30
