Thermal Flow Shock Rebuild
- BruceeD
Replied by BruceeD on topic Thermal Flow Shock Rebuild
Ahh thanks, not sure how I missed those
15 May 2020 19:17
#41
- Tjlee
Replied by Tjlee on topic Thermal Flow Shock Rebuild
The holes I am referring to are in the cylinder valve. They measure 3/64" / 1.19mm
Attached some pictures.
17 May 2020 11:42
#42
- BruceeD
Yep my YZ125 has those then the shaft has a hole that goes up a bit then a hole drilled through the side of the shaft to intersect that hole.
17 May 2020 15:32
#43
- Le7316
Replied by Le7316 on topic Thermal Flow Shock Rebuild
So i will need two of these on each side of the shocks and thats it for the whole rebuild process ? or there are other seals that i need to purchase ? Can someone confirm ?
Seal - AVX Part # TC12X23X7
19 Aug 2022 07:26
#44
- MACE6772
Replied by MACE6772 on topic Thermal Flow Shock Rebuild
You will also need 2 O rings. One large one for the reservoir cap and one small one inside the inner tube. They are metric sized. If you go to the Tech section and read " how to rebuild Thermal Flow shocks", I list the part #s and contact info for my source. I do not know how to translate the part # into a size. If you did not use heat to get the cap off, the large O ring will probably be OK to reuse. The article includes 2 pictures that show the small o ring and it's position on the shaft.
The following user(s) Liked this Post: MarkT, Snglsmkr, Ht1kid, Le7316
19 Aug 2022 17:38
#45
- Le7316
Could you post a link here ? I see the "How to Articles" under Tech Library but didnt see your post that you mentioned.
22 Aug 2022 08:10
#46
- Le7316
QUOTE " Oem stock bushings- 1M1-22216-00-00 come up on Flea bay sometimes. OEM part # 275-22123-00 will work but needs to be narrowed to .782" to fit. Don't forget Part # 90106-10025-00, These are the slightly longer OEM shock bolts you will need for the top if you are installing a luggage rack.
I BUY THERMAL FLOW SHOCKS"
MACE6772 ,
Do you happen to have the dimensions of the stock bushings of these shocks ?
MACE6772 ,
- RTD2
Replied by RTD2 on topic Thermal Flow Shock Rebuild
Found out the hard way today that the MX Thermal Flow seals are not 23mm they are (I hope) 28mm OD. I hope that helps someone else.
02 Sep 2022 19:24
#48
- automan
Replied by automan on topic Thermal Flow Shock Rebuild
RTD, where to find those 28mm seals?
cliff
cliff
03 Sep 2022 04:10
#49
- RTD2
Show:Not hidden
See orders from:Last 60 DaysFilter by:AllORDER DATESep 02, 2022ORDER NUMBER11-09054-65685SOLD BY irvinemanuser ID, click for member’s profile ORDER TOTALUS $31.96
Leave feedbackAVX Shaft Oil Seal TC12x28x6 Rubber Lip 12mm/28mm/6mm metric
(361455648663)
Quantity : 2Estimated delivery Wed, Sep 7 - Thu, Sep 8
PAID
Not yet shipped
Feedback needed
No Feedback receivedITEM PRICE:US $29.90
(361455648663)
PAID
Not yet shipped
Feedback needed
03 Sep 2022 07:40
#50
