spart
  • jsmith6752
  • jsmith6752's Avatar Topic Author
Replied by jsmith6752 on topic spart
I little afraid but I will give it a whirl...thanks any i9dea why the dash lights would blink with the turn signal?
29 Nov 2024 09:04 #11
Replied by Gr8uncleal on topic spart
Likely a bad earth/contact somewhere. Check all bulb fitments and contacts. Those sort of electrical gremlins can be a bu**er to pin down!
All original wires will be colour coded, so yellow to yellow, green to green etc and you shouldn't go wrong.
Last edit: 29 Nov 2024 09:15 by Gr8uncleal.
29 Nov 2024 09:13 #12
Replied by pabdt on topic spart
The yellow regulator wire goes to the dark blue wire that goes to the instrument lights (speedo/tach). You must also ground the regulator.
By attaching to the blue wire, as instructed by Yamaha, you essentially regulate not only the instrument lights, but power to your headlight hi/lo beams.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
29 Nov 2024 09:31 #13
jsmith, try reading over this post and see if helps on imgur posting. Looks like you are close to posting pics.
yamaha-enduros.com/index.php/forums/gene...mgur-pictures#176437
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 29 Nov 2024 09:41 by pabdt.
29 Nov 2024 09:40 #14
  • jsmith6752
imgur.com/a/WDH7aqW
i.imgur.com/Mha8cA6.jpeg
I have all the wire out of the bucket.several are not matching up color wise and some of the male ends have power.
29 Nov 2024 13:50 #15
  • jsmith6752
29 Nov 2024 13:53 #16
  • jsmith6752
I have a lot of black wires to hook up. Going to see if they are all grounds.
30 Nov 2024 07:47 #17
You got this.  Just remember, the general setup is power is routed to handlebar controls via main harness, to switches, then on to electrical devices on front of the bike. Turn signals, headlamp, horn, instruments. The key_sw connector is actually under the tank.
Information about Turn Signal Indicator Light:
The one circuit I found misleading at first is the turn signal indicator light (tsl)
The way Yamaha wired this was to put the (+) side of the tsl to one turn signal and the (-) side of the tsl to the (+) of the other turn signal. Note, when power is not applied to them, turn signals are default grounded if they have a bulb with a good filament, so one side of the tsl is always (+) and other (-) when a turn signal is activated even though both sides are theoretically connected to a (+) power source.   *hopefully I got this right.
Every time I look at these old bikes I find more amazing engineering.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
30 Nov 2024 14:55 #18
  • jsmith6752
time to see if I can put humpty dumpty back together again
01 Dec 2024 07:38 #19
  • jsmith6752
1st question of the day. I have a light blue male wire in the headlight. Any ideas? thanks
01 Dec 2024 11:11 #20
Moderators: yamadmin, Makotosun, DEET, Vinnie
