1978 yz250E front fork stanchion tube dimension above top triple clamp
- Joe1028
1978 yz250E front fork stanchion tube dimension above top triple clamp was created by Joe1028
Hi,
looked but can not find the stock front fork tube protrusion above the top triple triple clamp and the min and max dimensions... 78 yz250E..
thx, Joe
thx, Joe
21 May 2026 21:02
Replied by MarkT on topic 1978 yz250E front fork stanchion tube dimension above top triple clamp
I'm not 100% sure on the YZ, but on many models of that era with forks that extended through the clamps, Yamaha scribed a line on the fork tubes that lines up with the top of the triple clamp.
I can't recall ever seeing a "min/max" but there might be one? I'll look and see if I have a Yamaha Competition Tuning Manual for a 78.
21 May 2026 22:18
Replied by RT325 on topic 1978 yz250E front fork stanchion tube dimension above top triple clamp
Pretty sure they do have a scribed line to set flush with the top. But it's a bit of personal preference really. But don't go so far through that the wheel might hook the guard on full compression. Good model you have there, that & the 400 in 1978. I got the 400 new one "79, a one year long stroke motor & was my favorite looking back.
22 May 2026 04:49
- Joe1028
Replied by Joe1028 on topic 1978 yz250E front fork stanchion tube dimension above top triple clamp
Thanks will check for machined rings like a lot of forks have...
22 May 2026 16:56
- Joe1028
No machine marks on stanchions..
Found out the yellow after market gaitors actually bind as it nears full compression...odd , so any one have a source dor good gaitors at a fair plrice...thx Joe
15 Jun 2026 17:36
Try DC Plastics for the boots.
I have the Yamaha manuals and nothing I can find has a spec for how far the tubes extend through the clamps.
15 Jun 2026 22:01
- Joe1028
Any one use dust seal wipers instead of gaitors and if so who sells them?
Joe
Joe
16 Jun 2026 08:32
- Joe1028
With springs out i can move tubes up 1 inch safely before contacting fender.. I moved it 1/2" and bike turns better. Will go another 1/4" for next race and see how it turns. Running 7# air in the forks, weigh 155#.
Joe
Joe
12 Aug 2026 03:13
