1974 Yamaha 360 Enduro...Clutch problem
  • pabdt
  • pabdt's Avatar
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic 1974 Yamaha 360 Enduro...Clutch problem
Thought about that after I posted. Could have been put on perfectly with no key and still fired at right or wrong time.
Glad to see you are up and running.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
26 Nov 2025 12:38 #51
Replied by Tom P on topic 1974 Yamaha 360 Enduro...Clutch problem
"The key was in but for some reason the magneto was not in far enough...you can tell now that where the nut is, some of the shaft sticks out beyond it, before, the shaft was inside the nut a bit...probably seated another 1/4" in..."
Key probably rocked upward on the inside, blocking the mag from going on fully. Glad it was easy to fix!
26 Nov 2025 16:30 #52
  • dart451
  • dart451's Avatar Topic Author
Replied by dart451 on topic 1974 Yamaha 360 Enduro...Clutch problem
Just thought I'd tell you guys that I did get the bike running again and the clutch works! In the manual it states that anytime you remove the magneto you have to re-time the bike. So, the bike runs but isn't terribly smooth so I guess I need to do the ignition timing again. You wouldn't think that seeing as the Pulser didn't move, it should still be in time and it does start and idle ok. Has anyone taken off the magneto and had the bike run normal after re-installing it without timing it again?
Last edit: 30 Nov 2025 09:47 by dart451.
29 Nov 2025 15:04 #53
