1974 Yamaha 360 Enduro...Clutch problem
- dart451
1974 Yamaha 360 Enduro...Clutch problem was created by dart451
Greetings to all,
Just aquired a 74 360 't disengage. I assume I need a new cable but is there a way to see if the clutch is working at all if I were to disengage the cable at the handlebar so I can pull the cable with pliers to see if she'll disengage at all? Thank you.
12 Nov 2025 11:30
Replied by MarkT on topic 1974 Yamaha 360 Enduro...Clutch problem
Why are you "assuming" you need a new cable? Generally, that's a pretty obvious yes or no.
Seriously doubt you can pull clutch with pliers from the handlebar end even if the cable is good.
Maybe you could give a better description of the problem? If you can pull the lever with resistance but clutch doesn't slip with lever pulled, probably just the plates stuck together which is very common after sitting a long while.
12 Nov 2025 17:20
- dart451
Replied by dart451 on topic 1974 Yamaha 360 Enduro...Clutch problem
Thank you for the reply! Did more checking this and the cable is pulling the lever all the way under the bike so, even though it may need a new cable, the clutch pack must be stuck. Gonna have to take the cover off and inspect. Thank you.
- pahiker
Replied by pahiker on topic 1974 Yamaha 360 Enduro...Clutch problem
Put it in 2nd gear, pull in clutch and rock it back and forth vigorously until the bike moves freely. If it breaks the plates loose you've saved yourself the trouble of removing the side case. It's worked for me a few times, good luck.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
2024 Suzuki DR650
13 Nov 2025 02:41
Replied by Gr8uncleal on topic 1974 Yamaha 360 Enduro...Clutch problem
If #pahiker's method doesn't work, try pulling the lever and then tying it to the 'bars and leave it for a couple of days.
If and when you replace the gearbox oil, make sure that you use oil suitable for wet clutches, otherwise you'll go from a bike with a stuck clutch, to one with a slipping one!
13 Nov 2025 04:59
- Schu
Replied by Schu on topic 1974 Yamaha 360 Enduro...Clutch problem
If the bike runs you can try the method I've used which is start the bike up and roll forward so that you can click it into gear without stalling the engine. Then go for a ride while you work the throttle back and forth. That has freed up the stuck clutch plates every time I've done it. I think it was Morley RT325 that taught me that method.
13 Nov 2025 08:32
- pabdt
Replied by pabdt on topic 1974 Yamaha 360 Enduro...Clutch problem
I would install a new clutch and oil.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
13 Nov 2025 10:46
- dart451
Where would I look for a new clutch pack? I've tried several places but all I've found is "Unavailable"...
13 Nov 2025 11:06
I would try the suggested fixes first - they'll cost you nothing.
13 Nov 2025 12:07
- pabdt
I think I ended up using raptor parts. Hey it’s no fun and cost me around $32, but worked well.
It is also possible you have a brand new clutch in there that needs release. Certainly Try that first.
I’ll post what my stuck one recently from an engine looked like.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
13 Nov 2025 15:13
