Replaced crank seal now clutch won’t engage
- bhepp15
Replied by bhepp15 on topic Replaced crank seal now clutch won’t engage
Couldn’t wait I dug into it today. From what I can see the clutch pack and plates are all installed correctly. I have pictures as well. When I grab the basket I can wiggle it back and forth a little bit. Is it usual for that to have some play? Other than that everything appears correct.
27 Sep 2022 13:37
#41
Replied by RT325 on topic Replaced crank seal now clutch won’t engage
Still worried about what's behind the center hub in regards to the thing flat bearing & its thin washer which may or may-not be incorrectly assembled. Does the center hub revolve freely as it sits in these pics. Plates look good being new of course.
27 Sep 2022 13:56
#42
- bhepp15
It spins freely. Took it apart. On washer behind the 29 mm nut and another covering the thin bearing. Not seeing any issues.
27 Sep 2022 14:26
#43
- 1971DT250
Replied by 1971DT250 on topic Replaced crank seal now clutch won’t engage
Check for:
# 19
2 of # 18 these are thick
The thin washer for # 17
# 19
27 Sep 2022 15:52
#44
- bhepp15
I have a washer in each side of that thin bearing. Haven’t looked behind it for #19 yet. And then a washer for the farthest out nut.
27 Sep 2022 16:07
#45
- bhepp15
Does that outer #18 go against the small bearing
27 Sep 2022 16:10
#46
Flat bearing in first pic needs a thin original washer to protect it from the small kick gear. In second pic you show a dark colored washer sitting on the kick gear. Is it the thin washer which belongs to the flat bearing. Other side of flat bearing is ok to run on the thick washer that's still in place there. It's a bit of a juggle to assemble without it dropping behind the spacer & getting pinched. But looks like you done it for without issues so--onward & upwards. Hope it all works in the end.
- bhepp15
Yes the washer on the gear goes to the bearing. I'm struggling to find anything that is wrong with my set-up. Could bad springs cause all this fuss as they are on the bottom end of spec.
27 Sep 2022 17:40
#48
Replied by MarkT on topic Replaced crank seal now clutch won’t engage
I have no facts or even a good argument to explain why... I just have had a gut feeling the problem is and has been in the worm gear actuator on the other side of the engine.
I'm not that familiar with the clutch layout on that engine but you have a few experts helping that I'm sure will make sure you get the clutch assembled right... hopefully that fixes it.
27 Sep 2022 18:39
#49
- bhepp15
That would be good news to me. It all looks good in the worm gear but I could be missing something.. now I gotta peice the clutch back together ha
27 Sep 2022 19:07
#50
