And just who do you think you are?
Replied by Mothersbaugh on topic And just who do you think you are?
I usually clean the inside of cables with WD-40 first, and then flush that out with a few sprays of brake parts cleaner. Then swing the sumbitch over your head rodeo style to clear as much of that as you can out.
One more thought on the sticking slide. If your carb is screwed onto the manifold too tight (beyond where your elbow pops once), the you can actually distort the shape of the barrel of the carb, and even a couple of thousandths can cause the slide to bind in the barrel.
Last edit: 28 Jul 2021 19:20 by Mothersbaugh.
28 Jul 2021 14:36 #1171
Replied by SKYDANCER46 on topic And just who do you think you are?
Make sure the throttle grip is not hitting or rubbing the handlebar end. Loosen one of the phillip head screws on the throttle housing and slid it out a bit. See if that doesn't help. While you are at it you can spray some silicone spray on the throttle tube that rides on the handlebar. Clean it first with a can of brakleen if dirty or gum up. You want to use a non petroleum spray or lubricant. Silicone spray is your best friend on these bikes.
By the way, Super nice looking CT3!
28 Jul 2021 14:48 #1172
Replied by famke on topic And just who do you think you are?
Mothersbaugh that imagery gave me a good chuckle at work, thanks! :D
I took the housing off of the handlebar and cleaned out the throttle tube and that metal tube part that's close to it. Big improvement! Thanks all for the advice! :)
And thank you SkyDancer, she's "cherry" as my brother said ;)
If it wasn't raining tonight I would have taken her for a quick little ride, so instead I just fired her up in the garage and sat on her for a bit after getting the throttle issue fixed. Getting plates and insurance on Friday so I can go riding with my friend on her 250 ninja :D
28 Jul 2021 19:01 #1173
Just putting science to work for me....
The following user(s) Liked this Post: famke
28 Jul 2021 19:21 #1174
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic And just who do you think you are?
"What do you suggest for cleaning? I currently have carb cleaner and WD-40 in the garage. Also, clean where exactly?... Sorry if that's a stupid question, bikes are still pretty new to me."
Undo the screwtop of the carb, remove slide (aka valve) and give it a gentle clean with Autosol. Do the same with the inside of the carb, where the slide "slides" up and down. This is best done with the carb removed, so as not to leave gobs of Autosol in the carb.
Saying all of that, it now looks like you're sorted!
28 Jul 2021 23:43 #1175
Replied by t-bone on topic And just who do you think you are?
If you haven’t changed the brake shoes yet please do so. They can delaminate and lock up the wheel at the worst possible time.
Very nice bike.
The following user(s) Liked this Post: Rick C., MarkT
29 Jul 2021 06:20 #1176
Replied by EastVanDad on topic And just who do you think you are?
My name is Dale and I'm a mechanical engineer from Vancouver BC, Canada. I just picked up a mostly complete 1972 DT2 from a buddy of mine that had too many projects in his garage and was willing to give this one up.
My current regular ride is actually an '89 Honda CB-1. I'm looking forward to the simplicity of the 2 stroke single for a change. Previous bikes include '82 CB125S, '81 RD350, '73 CB500 Four and wayyyy back in the day my first bike as 14 year old was a Rockford Tora 60 cc that died so I substituted the engine from an XL 75 from a high school friend. That was early Eighties.
Looks like this bike is mostly complete with a lot of parts in bins. The engine needs a piston and cylinder re-bore but it turns over fine. Electrics are all there but need re-doing. My present plan is to just to a basic restore and convert to 12v. I will tear the engine down to check everything before rebuilding. Tank is rusty and needs to be sandblasted, sealed and re-painted. Forks are a bit pitted too.  It will need lots of other little things but I have time. First thing is to get a service manual.
I'm all open to suggestions for restoration steps and recommended order of rebuild.
The following user(s) Liked this Post: Badger52
14 Aug 2021 22:10 #1177
Replied by RT325 on topic And just who do you think you are?
Welcome from NZ. Bike looks like a good one to start with & a few spares as well. Not a spare 360 motor, the other bits n pieces?.
15 Aug 2021 00:24 #1178
  • Gr8uncleal
Nice!
from the UK.
15 Aug 2021 00:44 #1179
Replied by Badger52 on topic And just who do you think you are?
The Tech Library has a service manual for your bike. Good luck with your project.
288501A
21 Aug 2021 09:10 #1180
