Life after meltdown
Replied by RT325 on topic Life after meltdown
Oversize rings usually have the oversize etched into the upper face of the ring. Not sure if that's still the case for the L shaped Dykes top ring though.
The following user(s) Liked this Post: yamayeeha
20 Jan 2021 02:42 #51
Replied by MarkT on topic Life after meltdown
Oversize Yamaha rings tend to have gaps on the bigger side of spec in my experience.
The following user(s) Liked this Post: Snglsmkr, Pete-RT1
20 Jan 2021 06:27 #52
  • msavitt
  • msavitt's Avatar Topic Author
Replied by msavitt on topic Life after meltdown
Thank you Mark
The top keystone ring has an “N25” and 2nd a “2N25” which to me means .25mm OS
So the question to you and the other experts is do I go with a 0.020” end gap, which in the end is a stack up dimensions and tolerances for a properly bored cylinder?
Or could I use a 2nd oversize and file to low end to get “0.012 gap?
Please advise, the goal here is to do this perfectly as possible!
20 Jan 2021 08:04 #53
  • msavitt
Thank you!
Needed a microscope but they are there!
20 Jan 2021 08:09 #54
Replied by Pete-RT1 on topic Life after meltdown
Recently I checked my CT1-C and the gap was 0.35mm (top limit), the bore measure great and so did the piston.
I offered up a new set of rings and the gap was 0.30mm.
Both sets felt tight in the bore so having asked the question MarkT said the same thing about the gap measuring bigger.
It's all back together and runs fine, so I'm not going to worry too much about the end gap dimension from now on, so long as it's not too much out of spec.
Yamaha CT3 (in bits)
20 Jan 2021 08:50 #55
  • msavitt
well...piston and bore perfectly within specs, rings are 1st OS with 0.020" gap and even if I wanted to try to fit a 2nd OS set of rings they don't seem to exist on planet Earth
So to the endurologists out there, do I forge ahead with a ring gap that's at the hi limit?
20 Jan 2021 11:11 #56
Replied by akara1 on topic Life after meltdown
it will run fine like that for a bit but you won't get too many hours on it before low compression and that will result in poor idle and hard starting. don't see why it would hurt anything.
20 Jan 2021 11:16 #57
  • msavitt
thanks for giving it to me straight
.25mm equates to .030" less end gap. If i am at .020 now, then 2nd OS rings get me to -0.010 meaning that buffing .011 off of each side of ring gap would put me at the ideal 0.012" ring gap
anyone know where i can get a 2nd oversize set of rings?
20 Jan 2021 11:35 #58
You'll be fine. A few extra thousandths of ring gap won't hurt anything now or later in my experience. Nor will performance suffer any sooner than it would if you managed to find a set of rings at the lower end of the spec.
:Buds
20 Jan 2021 11:36 #59
  • msavitt
thanks
I found a 2nd OS set on eBay for $30 and will fart with this a bit more before taking it any further
20 Jan 2021 12:06 #60
