1975 DT175 timing questions
- GJVGC
Replied by GJVGC on topic 1975 DT175 timing questions
Filter is new.
I took the air filter out, put in a new spark plug gapped to .6mm, tried a spare ignition coil and even flushed out the gas it had in it (wasn’t old)
Still same misfire under load at about 1/4 throttle and 4krpm
29 May 2020 12:56
#101
- Free
Replied by Free on topic 1975 DT175 timing questions
I opened the air filter and that isn't what I found in mine.
1975 DT175
29 May 2020 14:30
#102
- GJVGC
Hahaha hopefully you had something in there
I removed the carb to check the reeds
Lot of fuel/oil on it. Look ok?
I’m really thinking it is just running too rich. But I don’t know if it’s too much fuel or oil from the autolube pump.
- JimA
Replied by JimA on topic 1975 DT175 timing questions
Here is a pretty good video on the oil injection pumps. It helped me understand how to set it up. Hope it helps.
Jim
Jim
29 May 2020 16:16
#104
Replied by MarkT on topic 1975 DT175 timing questions
Boyesen reeds run rich. It's even in their instructions. It's no secret I'm not a fan of Boyesen reeds although many love them. But if you don't have the stock reeds, there's not much choice. I have a couple of bikes with them.
If it's happening at 1/4 throttle, you could try dropping the needle one notch. (Move clip one groove higher in the needle, which lowers it.)
The following user(s) Liked this Post: JimA
29 May 2020 18:06
#105
- GJVGC
Thanks for posting the video Jim.
Great explanation of the auto lube pump.
Im going to do the test to see if I am getting too many CCs. The alignment on the autolube pump on mine is right on.
I tried moving the clip and lowering the needle but it didn't make a difference.
I was noticing way too much fuel/oil on the new spark plugs.
I took the head off again and noticed a lot of fuel/oil on top of the piston.
- GJVGC
Verified the specs on the pump.
All seems to be within spec.
So what could be the reasons I am getting too much fuel?
This is driving me mad Hahahah
31 May 2020 13:17
#107
- Swoop56
Replied by Swoop56 on topic 1975 DT175 timing questions
Had to go through the entire thread to see if we had dealt with the carb earlier .
As I see we haven't , strip out the carb and see what is actually in there , as opposed
to what should be in there .
A previous owner may have fitted a carb kit . These frequently cause running issues
due to the brass hardware often bearing only a passing resemblance to OEM Mikuni parts .
Jet needles , which are usually brass in kit form , are the biggest culprit .
31 May 2020 14:36
#108
- GJVGC
Thanks swoop
I have been using this carb on the bike
yambits.co.uk/dt175-carburettor-p-94263.html
I do have the oem carb for the bike but the previous owner told me it needed a new one so I bought the one off yambits for $40usd.
Below is the oem carb and the jets off of it
Should I just rebuild the oem carb?
Replied by RT325 on topic 1975 DT175 timing questions
Try the std reeds. Bit of a story but modifying the porting on my 100 road race bike 'bucket racer' a lifetime ago, i ended up with a rich like blubber at 1/4 throttle. Couldn't carburate it out without going so lean it killed it. Smart mate of mine who worked on 'proper' race bikes said 'reed flutter'--double up the reeds==Damn it it foxed it straight away. Was an RT2 reed block housing welded into te back of a TS/TF100 Suzy cylinder with wild porting. Blubber was about where the pipe kicked in hard so maybe a bit above 1/4. I was still using the std Yam steel reeds so just added another set to stiffen them. Anyway--was just a thought from my experience.
31 May 2020 15:29
#110
