Choked up in low revs
  • pmgDT
  • pmgDT's Avatar Topic Author
Choked up in low revs was created by pmgDT
Hi,
I've only just started using my DT175C and on the throttle from idle to 4k revs it's choked up and as soon as it hits 4k revs it takes off like a scalded cat.
My guess is pilot jet? but maybe some other cause.
I've included a couple of links to videos of my son riding it. I've been teaching him to ride and he's coming along great.
Any help much appreciated.
Thanks, Peter
Getting older everyday
11 Sep 2019 13:31 #1
Replied by RT325 on topic Choked up in low revs
Sounds ok from where i'm sitting but to get a better idea get your boy to pull about two gears higher accelerating from low revs. Maybe keep changing up as he goes. Maybe i'm not hearing the audio very clearly as a lot of other noise like piston rattle--maybe its just general running noise & nothing more sinister.
Just rethinking, could you do a stationary video of it idling & then bring it up slowly through the cutaway/needle/ main jet area if you're realy worried about it.
The following user(s) Liked this Post: pmgDT
Last edit: 11 Sep 2019 16:07 by RT325.
11 Sep 2019 16:04 #2
Replied by run103 on topic Choked up in low revs
Its a 2 stroke. that bike sounds very good to me also. Make sure the air filter is not too restrictive and have fun.
Doug
11 Sep 2019 16:09 #3
Replied by MarkT on topic Choked up in low revs
Sounds pretty good to me... the only oddball thing I can think of is the advance mechanism in the flywheel might be sticking or modified by a previous owner?
Should be fully advanced not far above idle speed. You could check the advance movement with an automotive timing light.
11 Sep 2019 21:01 #4
Seeing i can't find anything wrong with it in the video-- can i point out the shocks should have the reservoir the the front. Well i had to pick on something didn't i --sorry. 9 out of 10 people do that, so ya not alone, & it doesn't matter.
www.partzilla.com/catalog/yamaha/motorcy...ar-shocks-chain-case
11 Sep 2019 21:27 #5
I'm pretty sure the thermal flows on the 1976 DT175's do not fit with reservoir forward unless you remove the chain guard.
yamaha-enduros.com/index.php/workshop-2/...uros/105-1976-dt175c
I just checked the pictures in the owner's manual... reservoirs are to the rear...
And yes... many people do mount them backwards on models that had them mounted forward... I think you have to on 76 175 with the factory "forward mounted" shocks.
11 Sep 2019 21:40 #6
moto7777.wixsite.com/redneckmechanics/dt175
Ok, in desperation to prove i'm right i've proved i'm WRONG. [Apologies] Hope my wife doesn't get wind of this or i'll be Apologizing all the time. Might add i've never ever seen them mounted rearwards from new & i would've assembled those new in "76 so that's it--memory is @##$%$d. So to start again--& not related to this bike--why do people have their headlight looking for possums up in the trees. Brand new bikes in advertising pics & light turned noticeably upwards. Interesting the Partzilla link shows it forward but can see what you mean by Chainguard getting in the way as i see the shocks are forward mounted on the arm compared with earlier models Still looks wrong back ta front lol. Look at the link, lots of pics.
Last edit: 12 Sep 2019 02:55 by RT325.
12 Sep 2019 02:55 #7
I wouldn't say you're "wrong"... Yamaha is for making a model that the shocks need to be installed backwards to fit. :haha
I can see it now... some smart engineer probably designed the new frame in 1976 and spec'd the Thermalflows and then got a call from production saying the shocks wouldn't fit without mounting them backwards... :Ugh
:Buds
12 Sep 2019 06:36 #8
  • pmgDT
Replied by pmgDT on topic Choked up in low revs
Thanks for your input guys. Probably difficult to hear but when you're on the bike you can feel it's sluggish in the low revs before it takes off at 4k.
I've leaned the mixture out a little as the plug is showing rich. Still ironing out some little bugs but it sure is fun to ride and my son loves it.
MarkT, I haven't forgotten you found that fuel tank for me so big thanks and it's just about still holding fuel after I had to have some pinholes repaired.
Thanks again, Peter
12 Sep 2019 08:58 #9
As MarkT says, check the timing advance. If its got the auto advance which i can't find looking though Partzilla--if it has then good idea to pull the flywheel & give the mechanism a grease up where the cam moves on the center. Once again--if it has--then someone might've fitted a heavier spring if the old one broke, in which case it could be holding back on retard until up in the revs. All pretty unlikely. Otherwise just check the points have a good gap up to 15thou & not less than 12 without worrying too much about timing just yet as should be in the ball park.
13 Sep 2019 05:07 #10
