Clutch cable not connected at clutch pak
- Huskyking
Clutch cable not connected at clutch pak was created by Huskyking
I am currently going through 73-RT3, in my process of putting front end back together i am installing levers and clutch cable.
I have found that my cable has come completely lose at clutch pack. I can actually remove it out of the case.....
Is this common,and is it a easy proceedure to fix. thanks
10 Aug 2026 10:28
Replied by Gr8uncleal on topic Clutch cable not connected at clutch pak
10 Aug 2026 10:33
- Huskyking
Replied by Huskyking on topic Clutch cable not connected at clutch pak
not sure what that part is, my situation is that cable can be removed right out of case, it is no longer connected
10 Aug 2026 11:32
Better take the cover off and have a look see!
10 Aug 2026 11:46
- Huskyking
yes for sure, thx
10 Aug 2026 11:56
Replied by RT325 on topic Clutch cable not connected at clutch pak
Clutch pack is on the other side. That's your actuator in there. Just pull that cover & sit the cable back in place. Could give the fitting a squeeze to stop cable escaping while doing stuff up at the handlebars. All a learning curve but it'll all become clear when you pull the sprocket cover/actuator holder thingy. Enjoy your time on the site. Plenty of help here & welcome from nz.
10 Aug 2026 15:32
- Huskyking
Thank you RT325, got everything organized and working properly, guess cable came off actuator when I was ripping bike apart....
Most time consuming part is getting shift lever off but with some gentle coaxing that worked out well....
thx to all others for input as well.
11 Aug 2026 16:57
