No Spark
- EricDT
No Spark was created by EricDT
Hey DT Riders,
I have a '73 DT3 250 and I've had the stator restored with new points and condenser. The gap is set right, the Ignition coil is new, and appears to have voltage reading on volt meter when kicked over. No spark at the plug with cap attached. Any ideas will be appreciated. Thanks
11 Aug 2022 17:35
- alnarv
Replied by alnarv on topic No Spark
Start by cleaning those points. New points often have a film which prevents good contact. Spray with contact cleaner (or even rubbing alcohol) then close them against a clean business card and pull thru.until it comes out clean.
The following user(s) Liked this Post: Tinkicker, EricDT
12 Aug 2022 05:28
- Andy_C
Replied by Andy_C on topic No Spark
Is the pug new or old - even new plugs can sometimes fail, worth trying another plug.
Also plug cap - is it a resistor cap? sometimes they fail.
Ex Yam DT400C, Triumph Trident 660, Triumph 865, Kawasaki KH 400
The following user(s) Liked this Post: EricDT
12 Aug 2022 08:30
- YamahaForumUsername
Replied by YamahaForumUsername on topic No Spark
is the key in the ignition and turned to first or second position.
13 Aug 2022 08:41
- EricDT
Replied by EricDT on topic No Spark
I think it is a resistor cap. I'll try another cap. Thank you
15 Aug 2022 15:24
- EricDT
I usually try the second position. Thank you.
15 Aug 2022 15:25
- EricDT
I sanded the point with 600 grit, Now I'll try cleaning with alcohol and business card. Thank you!
15 Aug 2022 15:27
Replied by RT325 on topic No Spark
Run the black from the mag direct to the plug coil to eliminate any problems elsewhere.
15 Aug 2022 16:40
- OkieDeric
Replied by OkieDeric on topic No Spark
If it is a resistor cap use a non resistor plug. I had the same thing with my dads 72 250. No spark with the NGK BR8ES but spark with the B8ES I pulled out of my Honda. We used a champion plug which cross referenced with the B8ES.
22 Aug 2022 12:24
- Swoop56
Replied by Swoop56 on topic No Spark
Another solution would be to change to a non resistor cap . Then you could use
the readily available resistor plug .
22 Aug 2022 12:58
