SC500 fires but will not start
  • stwsam
  • stwsam's Avatar Topic Author
SC500 fires but will not start was created by stwsam
I am at a high level of self-inflicted frustration.  1973 SC500 which was running fine except would not idle well. Re-checked carb, made are sure all jets were clean and clear. Running factory spec 80 pilot and 400 main. Correct needle in middle position. Bike will fire but not start. I have checked and rechecked carb jets and float bowl level. Replaced needle jet. Set timing to factory 2.7 mm btdc. Re-checked this numerous times.  New plug, change plug etc.
Checked spark coil and cdi ohm values and all in spec(oem cdi.)  Replaced flywheel crank seal for good measure as it was suspect.  Just removed decompression valve, cleaned, new o-ring and crush washer.  With compression guage cylinder is pushing near 120 psi.
 Checked kill switch.  I simply cannot get the bike to start.  I have been fiddling with two strokes since I was 13. I am 69 and completely baffled.  I feel like it is something simple.  Please for the love of Pete, someone steer me in the right direction.
fuel, air, spark, compression. it "ain't " that complicated!"
Last edit: 29 Nov 2026 18:02 by stwsam.
29 Nov 2026 17:53 #1
Replied by Gr8uncleal on topic SC500 fires but will not start
 from near Salisbury, UK.
I feel that any reply of mine runs the risk of teaching granny how to suck eggs! However, I'll give it a go.
Does it run on easy start spray? I wonder if fuel is getting through to the cylinder? Is the plug badly oiled after trying to start?
If you haven't done so already, go back to the plug that it ran ok on - lots of fake NGKs out there. I think that quite a few members here prefer the Autolite (I think that's the correct make) plugs.
Plug gap correct?
As I said, apologies if you've tried all of these already!
30 Nov 2026 01:24 #2
  • stwsam
Replied by stwsam on topic SC500 fires but will not start
Plugs are genuine and have even tried iridium and b8es non resistor. Plug does not oil up at all.  Will give sure start a whirl.  Tries a few drops of fuel in the cylinder but no joy. I have today connected with retired Yamaha master tech. He is going to take it on.  Will post what final result is when resolved.  One thing that drives me nuts is when a thread starts somewhere and originator never completes the loop when they find resolution. This is a great forum.
Last edit: 30 Nov 2026 07:22 by stwsam.
30 Nov 2026 07:19 #3
