Trailing Arm
- Drac56
Trailing Arm was created by Drac56
Top of the morninn or evening to y’all. Since my last poke for advice here, I’ve inherited another RT1 70… im getting the frames ready for painting but 2 and #3 is giving me some grief removing these trailing arms, the pivot
shaft / —-> collars. Im guessing the shaft is having a vulcan metal meld somewhere inside.
suggestions?
Drac
suggestions?
Drac
28 Nov 2026 22:21
Replied by RT325 on topic Trailing Arm
Best bet or 'what I do' is I have a steel tube, just galvanized water pipe, welded to a heavy steel plate. I lay the pike horizontal sitting on the tube which sits over the bolt head. But wait it gets better lol. Then I have an old honds crank pin with a long handle welded to that. I get my wife to hold the handle with crsnk pin in place on the bolt thread then hit it with a #$%%^ big steel sledge hammer. They always move!!. That way you're not directly hitting the thread but doesn't end up pretty never the less but sort that bit later. Done it this way at work with farm bikes rusted in which was common. I have a photo of the last one of my own I did. Just an old size mudbug I was given. Bolt came out but was hanging on tight for sure. Can go a bit then tap it back then go again if need be. I'll try to link my pic for a laugh. photos.app.goo.gl/5EDk1GENgthzFPks8 I obviously didn't have a handle on that crank pin. Wife must've been out that day haha so had to improvise & just balance it on the bolt. Mightve had the flange type nut just flush & inverted to give a wider surface for the crsnkpin. But wouldn't be any more than flush or problems would arise getting the nut off after smacking it.
The following user(s) Liked this Post: Snglsmkr, Ht1kid, Andy L, Drac56
- Drac56
Replied by Drac56 on topic Trailing Arm
RT.. the pike … serves as the base to stop any chance of bending the flange.. correct?
the other end. Your honda crank pin.. Tell me ., do ya leave the nut on the thread initially. Then remove it and pile drive it through the arm? I worry about smashing threads.
i stopped last night with a double jack. Concerned, I’d bend the flange.
good idea on the oversized water pipe.
Thanks..
Drac
Thanks..
Drac
29 Nov 2026 15:25
- Rick C.
Replied by Rick C. on topic Trailing Arm
KROIL !
The following user(s) Liked this Post: pabdt, Ht1kid
29 Nov 2026 16:17
Hope the photo link came up in the text but yep the steel tube sits over the head & against the frame bracket. Pretty sure on that one i had a flange nut flipped over so the flange part is up to give the crank pin a wider support. Depending how reluctant it is to move you could still damage the thread or bend it. You can see the size of the steel sledge hammer i used which is a bit over the top large but nothing much argues with that haha.
photos.app.goo.gl/Gbht8Yb43UNTpSSP6
The following user(s) Liked this Post: pabdt, Drac56
29 Nov 2026 16:22
- Drac56
Before i turned into John Henry… i thought I’d try this.
NO JOY .. 20t wouldnt move it
drive.google.com/drive/folders/1IpQTF3f-...G9EDu5Je_XRkIU42EO2h
so.. i drilled a 9/64 hole in the center of arm shaft. Stuck the WD “penetrating” nozzle inside this orfice and filled it up.
off on a work trip today, check it next weekend.,
Thanks guys.
Thanks guys.
30 Nov 2026 05:52
