'79 IT175 Squish band
- davidivjak
'79 IT175 Squish band was created by davidivjak
Hey guys,
I just bought a '79 IT175 with low miles and very good condition all in all! It has been collecting dust in a garage for years before I pulled it out, so I took of the top end before trying to start it. I inspected and cleaned everything, it still has standard piston and cylinder surface looks really good. After reassembling I measured the squish band and got something about 2,0mm-ish. In my opinion that's a lot, but I am entirely new to the IT-world. In our RDs we aim for 1,2-1,4mm. Luckily the spec sheets say how much the combustion chamber volume it should have, but nothing about the squish band.
So what do you guys aim for? What would you suggest?
Thanks!!
Kind regards,
David
Thanks!!
Kind regards,
David
'81 DT175MX | '72 R5F | '82 RD350LC | '79 IT175F | '74 MX175A | '78 YZ125E
22 Nov 2026 01:06
Replied by RT325 on topic '79 IT175 Squish band
Unless it's got a thicker base gasket or head gasket than normal I guess that's what the factory decided was ok. Not going to hurt to take it down a bit closer as easy to spin in the lathe with center plug thread. Some Yamahas maybe IT175 but 490 by memory came with double head gadgets & carb restrictor washer in the inlet rubber reed block. Still had bulk power but man did it take off when we removed both things at work [for the bosses son]--he thought we were magic haha.
22 Nov 2026 12:26
- 84Prerunner
Replied by 84Prerunner on topic Re:'79 IT175 Squish band
I just put a new top end on my 73 CT175. Had the machine shop take .012” off the deck surface. Can’t remember the exact squish I ended up but it’s right around 1mm.
Sent from my iPhone using Tapatalk
22 Nov 2026 21:56
