CT3 Clutch & Shift Question
Replied by MarkT on topic CT3 Clutch & Shift Question
I don't know how you got the clip and washer on without the selector in place on the drum.
Something isn't right.  The clip and washer keeps the shaft from sliding in and popping off the drum.  Did you force something to get the clip and washer in place?
29 Aug 2021 14:23 #11
  • Quartermaster35
  • Quartermaster35's Avatar Topic Author
Replied by Quartermaster35 on topic CT3 Clutch & Shift Question
Mark,
The cir clip went back relatively easy once I had access to it........
I pulled off the right side case to check things out and the claw arm is popping off out of place from the shift drum.......  When I place it on the drum while the case is off it shifts just fine.   But it came off when I put it all back together.
Any additional thoughts for me?
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
29 Aug 2021 15:46 #12
Can you take a picture of the clip (shift lever) side?
29 Aug 2021 16:05 #13
Replied by RT325 on topic CT3 Clutch & Shift Question
Think i'll have another cuppa. Wonder if the arm has got bent away with whats been going on but shouldn't really happen. Has someone put a thick washer on the shaft behind the return spring but that's compromise getting circlip & washer on the other end so was just a thought. From where you are with cover off it'd be easy to pull it out & check. Then sit arm on & washer plus circlip the other end & cycle it through the gears with cover off & see if--or why--it climbed off.
29 Aug 2021 19:06 #14
Could you have bumped the shaft before circlip & washer were back on.
29 Aug 2021 19:07 #15
I'm wondering if clip is under the seal?  (If the seal is installed at all)
29 Aug 2021 19:11 #16
  • Quartermaster35
OK.....Mark & TR325
The cir-clip was off again  ........    I have anew one on order so when it arrives I will install and push it back and forth to make sure that it is seating in the shaft "grove" properly.
Thank you for the continued advice.....
Worst case, the entire shaft mechanism with dog leg etc is only $36 new from Partzilla
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
30 Aug 2021 17:35 #17
Make sure you clean the crud out of the groove....
Snap rings and e-clips have a sharp edge and a rounded edge...  happens with the manufacturing (stamping) process.  Make sure the sharp edge of the clip is facing out towards you when installing in groove.
30 Aug 2021 18:06 #18
  • Quartermaster35
Good advice......  I'll do both for sure.
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
30 Aug 2021 18:29 #19
Things that just shouldn't happen under normal circumstances.
The following user(s) Liked this Post: SKYDANCER46
30 Aug 2021 19:15 #20
