Exhaust pipe outlet
- Jimbobaroobob
Exhaust pipe outlet was created by Jimbobaroobob
Hi all
DT3 exhaust pipe outlet ‘baffle’ tube - should there be a nut and bolt (or self tapping screw?) holding it in place? Mine has a hole but nothing in it.
James
James
08 Feb 2026 08:33
Replied by MarkT on topic Exhaust pipe outlet
Yes, was probably 6mm x 10mm pan head screw with lock and flat washer,
The following user(s) Liked this Post: Snglsmkr, Jimbobaroobob
08 Feb 2026 08:43
- Jimbobaroobob
Replied by Jimbobaroobob on topic Exhaust pipe outlet
Thanks Mark, I guess it would originally have had a captive nut on the inside.
15 Feb 2026 03:54
- Swoop56
Replied by Swoop56 on topic Exhaust pipe outlet
No captive nut , the baffle hole was threaded to accept the screw .
The following user(s) Liked this Post: Jimbobaroobob
15 Feb 2026 12:42
- Jimbobaroobob
Thanks all, I’ll try and run a 6mm tap through it
22 Feb 2026 11:31
