1973 RT3 360 Cable Routing Diagram
Hi,
I'm just restoring a 1973 RT3 360 and wondering if anyone had a cable routing diagram please?
John
12 Feb 2026 10:21 #1
Replied by pabdt on topic 1973 RT3 360 Cable Routing Diagram
Might not be same exact bike, but the 74 DT360 service manual has detailed routing info for wiring/cables, etc towards back of manual. Maybe you could get some ideas from that. There may be one, but I didn't see a document for what you are asking in the 73 manual.
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1973 Yamaha DT3 250
1974 Yamaha DT125A
The following user(s) Liked this Post: J.D
12 Feb 2026 13:42 #2
Replied by SKYDANCER46 on topic 1973 RT3 360 Cable Routing Diagram
Pretty much all the 68-73 DT 250's and RT 360's are the same. All cables come up the right side of the frame above the front gas tank rubber puck mount. The throttle, clutch and front brake cables come up thru the space between the speedo and tachometer behind the ignition switch. The clutch cable comes up near the fuel petcock and crosses the frame under the gas tank to the other side behind the ignition coil so it can run up the same side as the tach, throttle and oil pump cable.
If you have your decompression lever mounted on the top side of the handlebar then i run that cable thru the area behind the speedo and top triple clamp then down below the lower triple clamp right behind the horn thru the frame to the decompression valve mounted on the cylinder. Some guys mount the lever on the underside like on the RT2 so you can run the cable between the gauges with the others.( see image of the RT2 below) Not my bike.
Be sure to leave the cables loose so they can move freely under the gas tank when your moving the steering full left and right. You can use some Yamaha metal tie bands to hold them up in place but not tight against the frame. You should have a piece of foam that goes on the rear of the backbone frame and taped on.
It's a little hard getting the gas tank rubber pucks over the cables when sliding the tank on but be sure the cables run above the mount so when the gas tank is on the cables can move freely back and forth under the gas tank.  You can check them with your hand once the tank is mounted.
All electrical wires come up the left side of the frame to the headlight bucket.
I included a couple picture of a RT3 i was restoring years ago to get a look at the routing.
The following user(s) Liked this Post: MarkT, Snglsmkr, Schu, Ht1kid, RZ350Dave, J.D
Last edit: 13 Feb 2026 08:26 by SKYDANCER46.
12 Feb 2026 18:15 #3
Replied by J.D on topic 1973 RT3 360 Cable Routing Diagram
The following user(s) Liked this Post: Whit, RZ350Dave
13 Feb 2026 01:46 #4
Thanks SKYDANCER46 thats great information.
Unfortunately I'm unable to see the photos that you uploaded. They all say Content not viewable in my region.
Thanks again
John
13 Feb 2026 01:55 #5
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic 1973 RT3 360 Cable Routing Diagram
You're in the UK then, John?!
from near Salisbury.
13 Feb 2026 02:50 #6
  • Gr8uncleal
John
I've sent you a message to have a read of.
13 Feb 2026 03:34 #7
J.D
if you would like the pictures i can e-mail them to you. Send me a message with your e-mail.
Rob
13 Feb 2026 08:18 #8
