Brand New Yamaha Petcocks for our bikes!
Replied by Dave Schaub on topic Brand New Yamaha Petcocks for our bikes!
My 1977 dt 400 goes to the left and is part # 1m1-24500-03-00 does one of these cross ?
28 Sep 2015 16:54 #31
  • Makotosun
  • Makotosun's Avatar Topic Author
  • Administrator
  • Administrator
Replied by Makotosun on topic Brand New Yamaha Petcocks for our bikes!
Can you post up a picture of what it looks like? I think if I recall that it needs to extend down from the tank a bit more than the one pictured above in order to clear the tank seam. If that is correct, then you need one kind of like the TW200 uses. Here are the part numbers that DEET posted up as being generally compatible. Note that the one that has the handle down a bit has a slightly smaller flow:
23F-24500-00-00
List $16.02, Net $12.09
Outlet: 6mm (3/16")
Handle sits about an inch below the tank
Right side outlet
3JN-24500-02-00
List $17, Net $12.15
Outlet: 7mm (1/4")
Handle is close to tank
Right side outlet
2GU-24500-02-00
List $26.77, Net $18.59
Outlet: 8mm (5/16")
Right side outlet
The following user(s) Liked this Post: TreasureState
28 Sep 2015 17:21 #32
Replied by johbru on topic Re:Brand New Yamaha Petcocks for our bikes!
Where was this a week ago lol I need to look though this site before I buy any other parts for my bike
Sent from my Nexus 6 using Tapatalk
28 Sep 2015 23:45 #33
  • Makotosun
  • Administrator
  • Administrator
Replied by Makotosun on topic Re:Brand New Yamaha Petcocks for our bikes!
We're here for you, Bro! Most all of us have been in the same boat, which is one of the reasons this site exists - to help folks avoid the (sometimes very expensive) mistakes others have made.
The following user(s) Liked this Post: johbru
29 Sep 2015 08:00 #34
55x-24500-02-00 looks like it would work but don't have specs,Thanks
29 Sep 2015 17:02 #35
Replied by Devin on topic Brand New Yamaha Petcocks for our bikes!
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=351314312345&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
shown on 1978 DT400E tank
The following user(s) Liked this Post: Dave Schaub
Last edit: 29 Sep 2015 18:10 by Devin.
29 Sep 2015 18:08 #37
Replied by RhinoDT on topic Brand New Yamaha Petcocks for our bikes!
FWIW, the 3JN-24500-02-00 petcock can be used in lots of other non Yamaha applications, can be used also to rid yourself of a faulty vacuum operated petcock as long as the vacuum port is plugged.
25 Nov 2015 10:12 #38
what have you guys used for sealing washers on the mounting screws?
28 Feb 2016 08:38 #39
  • Makotosun
  • Administrator
  • Administrator
Get the factory petcock washers from Yamaha. Still available, and still the best solution! They have a sealing washer built in.
Sent from the Cloud
The following user(s) Liked this Post: Dave Schaub, TreasureState
28 Feb 2016 22:40 #40
