Brand New Yamaha Petcocks for our bikes!
- DEET
- Moderator
Replied by DEET on topic Brand New Yamaha Petcocks for our bikes!
Keep in mind Yamaha makes more than just this one with several options.... all just as cheap.
Outlet configuration.... left, right, down, rear.
Out let diameter.... 3/16", 1/4", 5/16"
www.yamahaenduro.com/showthread.php?t=18828
The following user(s) Liked this Post: Makotosun, MarkT, mamllc, TreasureState
28 Sep 2014 20:07
#11
- Makotosun
- Administrator
Replied by Makotosun on topic Brand New Yamaha Petcocks for our bikes!
There are a number of alternatives. This particular one works really well on the Enduros I have used them on. Of course, you did the research! Throttle which is most appreciated!
The following user(s) Liked this Post: TreasureState
28 Sep 2014 20:49
#12
- Visitor
Replied by on topic Brand New Yamaha Petcocks for our bikes!
Good Info
But I feel more confused as I am torn between both
1, New style more miles and less work
2, Old original one refurbed for VJMC showing
I want to use mine but show it and to get it look like it's 2 or 3 year old look so I can blast it and show it
and a link so you can buy bits to do most of the job
Click Here
Click Here
- Makotosun
- Administrator
Clearly for a 100 point restoration, you will be better off with a refurbished original.
You may find some of the functional rubber or strainer parts not available, and if they are, they will be made of original materials. Why do I think this is an issue? Because we are getting far different fuels today than when the old rubber bits were made. We now have the wonder of Ethanol. New fuels can have negative effects on old materials.
The new petcocks are for many current model bikes, which will use more resistant (read long-lived) materials for modern fuels. That and they are under $15 and are factory parts!
For a rider (like all of mine) I choose function over form . . .
- Rick
Replied by Rick on topic Brand New Yamaha Petcocks for our bikes!
I'm going to use one of those 3JN-24500-02 petcocks Makotosun mentioned, but I'm wondering about the screws and washers. I have my original petcock screws, but the heads aren't the greatest. They'll work, but my main concern is that I get washers that will seal. Has anyone used the washers or screws that Partzilla shows for the above petcock on a DT3, or do I need to look elsewhere?
10 Jan 2015 14:30
#15
- Makotosun
- Administrator
You can use those just fine, or order the original seal washers. They may be the same.
Some folks have used fibre washers, but I have had little luck with anything but the originals. The problem is the gas follows the threads OD the mount screws if the washer doesn't kind of squish into them. The originals are designed to do this and work.
I feel that eve though they charge a bit much for a couple of washers, avoiding gas leaks is worth it.
By the way, I am using these petcocks on all of my bikes they will fit - very happy with the results!
The following user(s) Liked this Post: Rick
10 Jan 2015 15:54
#16
- poppinwheelies
- Content Contributor
Replied by poppinwheelies on topic Brand New Yamaha Petcocks for our bikes!
I didn't see 1973 RT3 on that list, but the parts catalogs I looked at seemed to indicate that it took the same petcock as many of the bikes on the list, any confirmation that these would also fit an RT3 tank? Thx
20 Mar 2015 21:46
#17
- Makotosun
- Administrator
dEET did the original research. He may have a tank he could verify with. My somewhat educated guess is . . . It should.
The following user(s) Liked this Post: poppinwheelies
20 Mar 2015 21:49
#18
- DEET
- Moderator
Yes, they fit RT3.
21 Mar 2015 04:58
#19
- AT6 DRIVER
Replied by AT6 DRIVER on topic Brand New Yamaha Petcocks for our bikes!
1975 DT 400B
If it moves and shouldn't , use duct tape. If it doesn't move and should, use liquid wrench.
21 Mar 2015 05:32
#20
