QUIT AND WONT RESTART
  • chuckaluck
  • chuckaluck's Avatar Topic Author
QUIT AND WONT RESTART was created by chuckaluck
Was riding and it shut off about a block from the house. I have replaced points, condenser and spark plug. Tried resetting timing per the manual. Bought a TDC dial gauge just for the procedure. TDC and turn backwards 1,8mm and all that business.
Anyway, ive done the procedure at least a dozen times and best ill get is an occasional backfire mostly through the exhaust. Ive done some research and now think maybe the woodruff key on the crank has broke or bent. My question is whats the thread pitch on the end of the armature so i can pull it to get to the key? And is it a right hand thread or left hand. I can hit Fastenal to see if they have a bolt if i have the relevant information.
Thanks in advance for the help.
Bike is a 1970 AT1.
Last edit: 20 Oct 2026 15:14 by chuckaluck.
20 Oct 2026 15:02 #1
Replied by pabdt on topic QUIT AND WONT RESTART
Its been a while since I picked this up, but I think was off ebay, maybe amazon.
Recently removed a 74 DT125A armature w/it.
On that bike, make sure the battery is charged.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
21 Oct 2026 23:15 #2
Replied by MarkT on topic QUIT AND WONT RESTART
If you are able to set the timing to 1.8mm BTDC, the woodruff key cannot be the issue.
Make sure advance is blocked open per manual when setting.
The following user(s) Liked this Post: DVM
22 Oct 2026 05:55 #3
And yes, charging your 12v battery would be the first thing I'd do.
(And we're assuming this is a 12v generator/starter model.  Some countries got the AT magneto model option and occasionally you'll find one in the US. From what you've said, it sounds like you have a starter/generator.)
Last edit: 22 Oct 2026 06:02 by MarkT.
22 Oct 2026 05:56 #4
Replied by RT325 on topic QUIT AND WONT RESTART
Ignore me i'm way behind on the story & not fully read it yet.
Not mistaking tdc for bdc?--ok stupid thing to say but i can take the flack.
Has it blown the right side seal completely out if it just stopped on the spot & still had spark.
I gather it's an electric model [we have magneto], so is it possible to put the advancer in half a turn out--guess not as think its got a "thingy" to locate it.
But wait there's more-- I think the advance weights can be removed & then the cam could turn on the base when you weren't looking so half a turn out when refitting the weights.
Never mind--have a good day.
26 Oct 2026 17:06 #5
