Front/Rear Sprocket Combinations
  • 's Avatar
  • Visitor
  • Visitor
Replied by on topic Front/Rear Sprocket Combinations
What is a good source for what is stock? Mine says 38 or .39, and I believe that to be stock. I can't swear to it I'm third owner but it looks stock. I would go check the number on the back sprocket for sure, but I in bed .
Sitting on the Bluff
Last edit: 22 Dec 2014 19:17 by .
22 Dec 2014 19:14 #11
Replied by Devin on topic Front/Rear Sprocket Combinations
We have the manual in the downloads area. It may help with wiring the headlight. Here is the link:
www.yamaha-enduros.com/index.php/service...cument.viewdoc&id=52
I am seeing stock rear sprocket was 39 Tooth:
www.yamahapartsandaccessories.com/shop/p...T3_-_1973/REAR_WHEEL
22 Dec 2014 19:29 #12
  • 's Avatar
  • Visitor
  • Visitor
thanks i thought it was 39, all the stock looking ones on ebay are 44. But they are cut to look like the original sprockets. I'm sure I'm going to need the manuals very soon. Still learning my way around the board.
Last edit: 22 Dec 2014 19:34 by .
22 Dec 2014 19:32 #13
Replied by Devin on topic Re:Front/Rear Sprocket Combinations
It looks like the DT2/DT3 use 44 tooth, as mentioned earlier.
22 Dec 2014 19:34 #14
  • Makotosun
  • Makotosun's Avatar
  • Administrator
  • Administrator
Replied by Makotosun on topic Front/Rear Sprocket Combinations
Not sure which bike we are talking about, but if you go to the workshop, then specifications, we have a lot of the bikes in there. Here is an example:
yamaha-enduros.com/index.php/workshop/sp...2-rt3-specifications
Final drive is your sprocket sizing for stock.
22 Dec 2014 20:14 #15
  • 's Avatar
  • Visitor
  • Visitor
The ebay item id given is invalid, no result has been sent
thats really odd, someone must have bought out partsunlimited. and boats.net calls the part obsolete with no cross ref to a surrogate.
23 Dec 2014 09:28 #16
  • 's Avatar
  • Visitor
  • Visitor
i have a list of all internal gear ratios from 70-73 250-360cc if anyone needs them. gearing commander is really very accurate if you have all your info. RT1 RT2 RT3 DT1 DT2 DT3
23 Dec 2014 09:34 #17
Replied by TerryM on topic Front/Rear Sprocket Combinations
I got my replacement rear sprocket straight from PBI. Their online store is a little confusing, but this should link to the rear sprocket for the 250-360-400 series of Enduros prior to 1977.
www.shop.pbisprockets.com/product.sc?productId=399
23 Dec 2014 19:00 #18
  • 's Avatar
  • Visitor
  • Visitor
The 39 on my bike with less than 7,000 miles, looks like a good metal, not as shiny as the 44s I'm seeing on ebay.
26 Dec 2014 13:40 #19
Replied by DC Morris on topic Front/Rear Sprocket Combinations
Hey Mark, I spoke with you once before. I had that same little Yamaha 80 when I was a kid.
On the sprockets, I have a very low mile 81 Dt175. All original. I’d like to gear it up just a tad because first gear is like granny gear and I only ride it on the road. Don’t need that low of gearing. How do I go about figuring the correct front sprocket change? Would going one additional tooth do it! I’m not really into the ratios so I’m lost as to what to do.
The following user(s) Liked this Post: manxman
08 Jun 2019 11:57 #20
