Yamaha paint matches
Replied by Badger52 on topic Yamaha paint matches
Hey Lavern...
yamaha-enduros.com/index.php/workshop/wiki/127-1977-ty250d
The tech library has a model listing entry for your 77 TY250.
There is also a section in the forum for the TY models.
yamaha-enduros.com/index.php/forums/trials-of-the-ty-series
288501A
Last edit: 17 Dec 2022 07:40 by Badger52. Reason: added second link
17 Dec 2022 07:37 #151
Replied by LaVern on topic Yamaha paint matches
Badger52,
Many thanks for the links. The first link did provide a paint color, Windy Blue, but no actual paint code.   On the second link I found a start of a thread, "TY 250A paint code",  but no one has answered and the 1977 TY250  is a is a D series. Thank you for the links. Perhaps if I mention "Windy Blue" when the time comes, someone may be able to decipher that. If all else fails, with todays technology, I believe my tank and side panels are good enough to get a good color mix.  Thanks for reading and responding to my post.
LaVern
The following user(s) Liked this Post: Badger52
Last edit: 17 Dec 2022 10:14 by LaVern.
17 Dec 2022 10:12 #152
Replied by MarkT on topic Yamaha paint matches
LaVern,
The problem with decades old "paint codes" is they are completely meaningless these days for the most part.
That said, this forum has a lot of resources and it's possible a specialty paint company makes the color you are looking for.
First step in looking up your bike in the Tech Library literature...  specifically there is a "Model Index" that sometimes shows paint colors.... mostly for later models though.
Unfortunately, the 1977 493 series (0200101 to 0300000) does not have paint code listed.
There is also a "Yamaha ID numbers" list that shows the TY250D (493-200101 to 201551) paint color as "Windy Blue" which corresponds to what you found already.
Not done yet.  The "Model Index" doc also has a "Color Name" section.  Windy Blue has the abbreviation "WB" with a code of "00J4".
Searching the "Model Index" doc for the "WB" abbreviation unfortunately does not come up with any (hopefully newer) models that used that same paint.  Sometimes you get lucky and find a newer model that the paint companies list a paint match for.
Didn't help much but maybe a good paint store or Yamaha can do something with the 00J4 paint code.
The following user(s) Liked this Post: Badger52, AirborneSilva, Ht1kid
17 Dec 2022 12:16 #153
Replied by AirborneSilva on topic Yamaha paint matches
Finished up the tanks today, that 2K clear is awesome stuff!  I'll wait a few days then cut and buff.
EDIT:  I guess I should have added the color I used, it's ford's Screaming Yellow D6.
Last edit: 09 Jan 2023 02:30 by AirborneSilva.
08 Jan 2023 15:14 #154
Replied by Ht1kid on topic Yamaha paint matches
Looks awesome!!! You can use the spray max on your inter cases too
08 Jan 2023 15:40 #155
Thanks Wes, thought about using the spray max on the cases but don't want it to be too shiny, I know you can get semi gloss but might just as well save the money and use the PJ1.
08 Jan 2023 15:43 #156
Replied by Gnarles on topic Yamaha paint matches
Hello
I have a 78 dt250 and was wondering what is recommended to repaint my fenders. The sun has cooked off the surface to the plastic. Under the seat it appears to be painted. Was that a factory thing?I am used to plastics being a solid color that just would turn pink(Honda three wheeler comes to mind).
Anyway I would like to make the old girl look a little better than it's current state.It's just a drive, not a show bike.
TIA. Gnarles
Last edit: 11 Apr 2023 19:34 by Gnarles.
11 Apr 2023 19:22 #157
Replied by GaryInVA on topic Yamaha paint matches
Wondering what rattlecan paints you all have been using to paint engine cases, cylinder, head, exhaust, frame, and bits like kickstarter/pegs/shifter/brake lever for dirt bikes (mines a 79 IT400).
31 May 2023 14:41 #158
Replied by SKYDANCER46 on topic Yamaha paint matches
I use Dupli-color low gloss DE1634 heat paint for black engines and pipes. If you like a little more shine then go with semi gloss DE1635. I like low gloss best. For frame i use Dupli-color perfect match universal black bun0100. Sometimes i use Eastwood satin black high temp black on exhaust depending on bike.
31 May 2023 17:13 #159
Thank you so much for the info. Found it on Summit Racing for a great price. Time to start making the bike purty.
01 Jun 2023 06:34 #160
