exhaust screws seized
- ksours
exhaust screws seized was created by ksours
ct3- exhaust guard screws broke off and are seized . Penetrating oil for @ 2 weeks. Used a screw impact hand held driver- 3 of 4 broke- only 1 came loose. Used Heat- tap and heat- left handed drill- extractor, 2 broke- Drill and tap I guess. These screw bodies are below the lip. Any more suggestions?
25 Jul 2021 09:17
Replied by Gr8uncleal on topic exhaust screws seized
With the exhaust removed, use a pillar drill to drill them out - it's amazing how much more force you can apply with one of those.
Drill to a max of one mm less than the screw diameter and then tap new threads.
25 Jul 2021 09:21
- ksours
Replied by ksours on topic exhaust screws seized
Drilled and tapped. If I run into bolts as stubborn as these, I may consider tapping earlier. Thx.
25 Jul 2021 14:57
- Sneezles61
Replied by Sneezles61 on topic exhaust screws seized
I wonder if no-seize would stand the test of time... and heat..
Sneezles61
Sneezles61
25 Jul 2021 19:10
- ksours
Good thought. This is just to hold a guard on and doesnt matter if the screws want to loosen. On an AC unit then lock-tite but in this application just maybe.
Worth a try- Thx
Worth a try- Thx
25 Jul 2021 19:35
