Headlight keeps blowing out.
- Hammer
Replied by Hammer on topic Headlight keeps blowing out.
Sir,
See my message to you!
Hammer
Hammer
13 Feb 2018 01:20
#21
- monel12
Replied by monel12 on topic Headlight keeps blowing out.
Thanks to all for your input and advice....
1971 RT 1B
1971 RT 1B
1970 RT 1
1970 RT 1
1969 CT 1
1971 DT 1
1974 100MX
2016 BMW F700 GS
1982 Yamaha Towny
1971 CT 1
1975 DT400
1971 RT 1B
1970 RT 1
1970 RT 1
1969 CT 1
1971 DT 1
1974 100MX
2016 BMW F700 GS
1982 Yamaha Towny
1971 CT 1
1975 DT400
13 Feb 2018 07:50
#22
- Scottddove
Replied by Scottddove on topic Headlight keeps blowing out.
Hammer, I found the two wire trail tech regulator. One yellow and one orange wire? How do you wire it up? How would you adjust it?
Replied by MarkT on topic Headlight keeps blowing out.
The search on this forum is one of the many things that work very well... Here are a couple threads that might help:
yamaha-enduros.com/index.php/forums/gene...r-on-6v-yamaha#28737
yamaha-enduros.com/index.php/forums/gene...headlight-conversion
13 Feb 2018 11:07
#24
- Scottddove
Mark I did a search. Spent 2-3 hours in fact. Maybe just me but a lot of confusing contradicting information. I just want my headlight and illumination bulbs to quit blowing. So if I am reading all this right. You mount the trail tech preferably somewhere that get air. Brown wire goes to ground. Yellow wire goes to blue wires inside headlight bucket and this will solve the problem?
13 Feb 2018 12:34
#25
- monel12
I believe that’s correct. I, too have the same regulator coming and an HR led 6v bulb, and will get a conversion headlight housing that MAKO recommended.
1971 RT 1B
1971 RT 1B
1970 RT 1
1970 RT 1
1969 CT 1
1971 DT 1
1974 100MX
2016 BMW F700 GS
1982 Yamaha Towny
1971 CT 1
1975 DT400
1971 RT 1B
1970 RT 1
1970 RT 1
1969 CT 1
1971 DT 1
1974 100MX
2016 BMW F700 GS
1982 Yamaha Towny
1971 CT 1
1975 DT400
13 Feb 2018 13:43
#26
- Scottddove
To be clear I am running 6 volt bulbs in all my bikes. Will this trail tech regulator still do the job?
13 Feb 2018 14:26
#27
No. You would have to run a 12v headlight which will be dim at low revs.
Get the stock Yamaha "one wire" regulator. Used ones come up on ebay cheap if you look. Or use the three wire regulator DEET recommends. There are other 6V AC regulators out there but some don't work according to DEET.
More info:
yamaha-enduros.com/index.php/forums/how-...lator-shootout#43888
13 Feb 2018 14:54
#28
- Scottddove
Ok we’re getting some where. How does one wire up the three wire? I need 4 of these set ups so I need to not make a mistake on what I buy.
13 Feb 2018 15:10
#29
I've only used the one wire Yamaha.
IIRC the 3 wire has input, output, ground... best person to ask for more wiring specifics is member DEET (or maybe the seller.)
13 Feb 2018 16:04
#30
