Difference in Oil Seals
- jdsmetx
Difference in Oil Seals was created by jdsmetx
I"m changing chain and sprockets on my 75 DT250 and decided I needed to change the wheel bearings to. I went to Partzilla and found the bearing and seal but the seal I need is no longer available. I went to my oil seal web site www.avxseals.com and found a simular size 25x40x7mm but its a type TC oil seal. What is in the wheel is a DD type size 25x40x6mm. Question is, what is the difference between the two types? The cross section doesn't look much different?? Need a little input.
CT90, TL125, IT175, DT250, MX250, MX360, DT400x2, XR600, DR650, DL1000
05 Sep 2015 11:30
- Enduronut
- Founder Moderator
Replied by Enduronut on topic Difference in Oil Seals
Good question . . . don't know, but one of the d's probably stands for double lip . . . or maybe dual/double directional lip
For what bike, or what part number is it . . . I may have it.
05 Sep 2015 13:37
- jdsmetx
Replied by jdsmetx on topic Difference in Oil Seals
The seal is for the rear wheel part# 93106-25003-00 and on a 1975 DT250B. The number on the seal is DD25x40x6mm
05 Sep 2015 13:52
- Enduronut
- Founder Moderator
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=300950353579&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- DEET
- Moderator
Replied by DEET on topic Difference in Oil Seals
If you can't find them, I have some.
05 Sep 2015 19:37
- jdsmetx
Replied by jdsmetx on topic Re:Difference in Oil Seals
Thanks EN and Deet. I got one more local source I'm going to try but if it doesn't pan out I'll give you a shout!
Sent from my iPhone using Tapatalk
05 Sep 2015 19:43
Replied by MarkT on topic Re:Difference in Oil Seals
I think the "DD" stands for "double dust" or something like that. It is a dual "dust" seal not designed to actually seal anything from coming out... it's primarily designed to keep dust (and water) from going in. There is usually no spring...
A TC is a dual lip seal with a spring... the outer lip is a dust seal but the inner lip looks more like it's designed to keep things from leaking out.
If I couldn't get a DD seal, the TC would probably work "OK". But since the DD is available I'd go with that.
05 Sep 2015 20:09
- Tjlee
Replied by Tjlee on topic Difference in Oil Seals
Hi Deet and Enduronut,
Saw this post from 2015. I am also trying to find a rear hub DD type seal for 74 DT250
pn 93106-25003-00
everything on ebay is out of stock
Do you have any by chance?
Thx
pn 93106-25003-00
Thx
23 Oct 2020 16:10
- nhsteve
Replied by nhsteve on topic Difference in Oil Seals
If all else fails Speed and Sport has 72 of them. Maybe over budget at $25.57?
store.speedandsportinc.com/
24 Oct 2020 07:50
