1978 DT175 Battery To Frame Connection
  • MikeK-uk
  • MikeK-uk's Avatar Topic Author
1978 DT175 Battery To Frame Connection was created by MikeK-uk
Good day all,
My lighting / indicators don’t behave quite as they should. I won’t bore you with the details (not yet anyway!), but I’m going through it. One thing though… where is the battery negative to frame connection?
Many thanks,
Mike
04 Apr 2026 04:20 #1
Replied by MarkT on topic 1978 DT175 Battery To Frame Connection
Under fuel tank near ignition coil
04 Apr 2026 05:16 #2
  • MikeK-uk
Replied by MikeK-uk on topic 1978 DT175 Battery To Frame Connection
 Very good - thank you.
04 Apr 2026 06:15 #3
Replied by Gr8uncleal on topic 1978 DT175 Battery To Frame Connection
If the frame has been thickly painted or powder coated, then you will need to scrape this away from any area where an earth is needed direct from the frame.
The following user(s) Liked this Post: porschedude996tt
04 Apr 2026 06:58 #4
  • MikeK-uk
It’s not been painted and just hoping it’s corroded and dirty. And with a bit of a clean, everything will work perfectly. Optimistic I know!
04 Apr 2026 07:10 #5
  • MikeK-uk
Found it... two wires into single ring crimp bolted to the coil armature. It was painted and now cleaned up. I think the lights are now a micro-lux or two brighter, so time well spent! Thanks again.
07 Apr 2026 11:40 #6
