Pop, bang, splutter
  • DT-Steve985
  • DT-Steve985's Avatar Topic Author
Pop, bang, splutter was created by DT-Steve985
Well as some of you know I recently found a DT125a with a CT1 175 engine in great original condition.
Today I rode it for a small distance (14 miles) into work for the first time and when it warmed up it started to hold back then pop and finished in losing power.
I thought for a minute that I wasn’t going to make it however I still need to get home, lol.
Now it’s cooled down I tried to kick it over and it’s just popping and ‘fluffing’.
To me it sounds like fuel unless someone can tell me different.
Any ideas?
17 May 2022 01:58 #1
Replied by asco on topic Pop, bang, splutter
Sometimes’ popping means the stator is going (shorting) out. The bike could be running too lean? Many things.
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
17 May 2022 02:17 #2
  • DT-Steve985
Replied by DT-Steve985 on topic Pop, bang, splutter
I’m running it at 40/1 as recommended therefore 125ml of oil to 5ltrs of fuel.
it was running fine and then started having issues. I’ve just tried kicking it over and it is just popping and spluttering but won’t start now.
17 May 2022 02:43 #3
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic Pop, bang, splutter
Oil pump not working?
17 May 2022 03:45 #4
Replied by Schu on topic Pop, bang, splutter
Vapor lock? Loosen the gas cap. Vent might be blocked.
17 May 2022 03:55 #5
  • DT-Steve985
It’s mixed in the tank.
17 May 2022 03:56 #6
Replied by RT325 on topic Pop, bang, splutter
Ok. 100% guarantee its shorn off the flywheel key from having been off & not tightened sufficiently. Make that 50% guarantee & give myself a bit of leeway incase i'm wrong haha.
The following user(s) Liked this Post: Enduronut, Sneezles61
17 May 2022 04:45 #7
Replied by Pete-RT1 on topic Pop, bang, splutter
Need to pop the plug to get an idea of what's been going on and see if you still have a spark.
Mag side crank seal could have pushed out, happened on my CT1-B.
Could be a lot of things really, need to investigate.
Yamaha CT3 (in bits)
Last edit: 17 May 2022 05:33 by Pete-RT1.
17 May 2022 05:32 #8
  • Gr8uncleal
"It’s mixed in the tank."
Originally there was an oil pump, situated under the small cover at the front right hand side of the engine.
Oil tank is/was the tinware on the left side of the bike, accessed from under the seat. Has all of this been removed?
Edit - just had a look at your photos. Oil tank is still present, but I can't see any hoses from the tank to the pump or the pump to the engine, hence your running it on pre-mix.
Last edit: 17 May 2022 05:53 by Gr8uncleal.
17 May 2022 05:49 #9
  • DT-Steve985
Hi all, I managed to get it started again tonight but won’t idle. I’ve left the bike at work and will take some tools in tomorrow to investigate further.
once started I pulled the choke and it tried to die by suffocation, the same as what’s happening therefore I’ll remove and clean out the carb and see if that helps.
17 May 2022 10:05 #10
