Replacing clutch bearing on dt 360
Replied by msavitt on topic Replacing clutch bearing on dt 360
nice work!
I agree with MarkT to not replace unless necessary. In my case the shaft had a distinct step and the bearing was crap as a result of marinating in crud for 40+ years
you are going to love this bike.
Whatever you do make sure that you pressure test for leaks and have the right jets in carb and correct timing...I ended up having to buy a piston, not cheap
29 Apr 2021 14:00 #11
Replied by MarkT on topic Replacing clutch bearing on dt 360
Hmmm...  I think one of the trans bearings has been superseded incorrectly to a roller bearing on the DT360?  Someone will know.
29 Apr 2021 14:18 #12
  • treeves
  • treeves's Avatar Topic Author
Replied by treeves on topic Replacing clutch bearing on dt 360
I thought I had finished the bike last year.  I had taken the frame and a few other parts and had powder coated, repainted and rebuilt everything but motor, I thought I was through but had an air leak in crank seal because crank was pitted,  I have gotten cylinder back from boring 3rd over and piston.  I am waiting on the crankshaft to come back after being rebuilt.  Hopefully will have running again in a couple of weeks.  Thanks again for all the help
29 Apr 2021 14:23 #13
Replied by Snglsmkr on topic Replacing clutch bearing on dt 360
Not sure if this link works but MarkT is referring to an incorrectly online listed supersede number. That number will get you a roller bearing and not the ball bearing.
yamaha-enduros.com/index.php/forums/74-7...ission-bearing#76120
30 Apr 2021 04:12 #14
  • treeves
I did buy the roller bearing (93306-30517) that is covered on one side. I understand it does not matter whether you take the cover off or not.
30 Apr 2021 07:33 #15
