74 DT250 Where to Start?
- DouglasDT
Replied by DouglasDT on topic 74 DT250 Where to Start?
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=262420380050&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- Bdubya
Replied by Bdubya on topic 74 DT250 Where to Start?
The seller threw in a brand new seat cover. It looks just like the ones you have pictured. Great idea about putting in some extra batting. I'll keep that in mind. Thanks for the advice.
03 Jul 2020 18:54
#12
- Bdubya
Thanks Steve, I appreciate the advice. The seller put in a new lead acid battery so I guess I'll keep that for now. I don't have any plans to ride on the street until I make sure everything is safe. Nor do I have any plans to ride at night. So, the lights and electrical can wait for a while. I do want to tear in to that rear brake. Something is definitely wrong because it just locks up with the slightest touch.
I saw a pretty lengthy thread on rebuilding those thermal-flow shocks. I'll have to look at that more closely. Not sure I want to tackle that, but might be a fun winter project.
03 Jul 2020 18:59
#13
- yamahoper
Replied by yamahoper on topic 74 DT250 Where to Start?
You could remove the springs , run the stroke and check for resistance both directions. If you have ,I would remove the large reservoir cap, drain , clean , add fresh fork fluid, clean the springs with brillo pad reassemble , about an hour worth of effort
The following user(s) Liked this Post: Tex68w
04 Jul 2020 13:48
#14
