Yamaha CT1 piston swap to a Honda MR
  • coxey2
  • coxey2's Avatar Topic Author
Yamaha CT1 piston swap to a Honda MR was created by coxey2
Thanks to Mr H. a fine member here donating a CT1 piston for measuring research; I may be close to finding a match for my Honda MR175 project. The Yamaha piston is 6.6 mm shorter but everything else is close. A question for you two stroke experts: how much does 6.6 mm shorter on the piston shirt effect timing etc? thanks
23 Oct 2019 13:45 #1
Replied by MarkT on topic Yamaha CT1 piston swap to a Honda MR
Something to check is that at TDC the skirt on the CT piston is long enough to cover the exhaust port.
If it's not, the crankcase will be open to the exhaust port at TDC which is not a good thing.
I will look for the DT200 piston again tonight... probably will be late
23 Oct 2019 16:25 #2
  • coxey2
Replied by coxey2 on topic Yamaha CT1 piston swap to a Honda MR
thanks going to do that now.
23 Oct 2019 16:48 #3
  • coxey2
yeah exhaust port is covered by at least 10mm at tdc.
23 Oct 2019 16:55 #4
Replied by RacerClam on topic Yamaha CT1 piston swap to a Honda MR
WEll if the intake skirt is 6.6mm shorter it wont idle and bottom end will be non existant but will scream on top end . Unless it is a reed valve engine , which it is not .
Rich
racerclam
23 Oct 2019 20:05 #5
  • coxey2
Those honda MR175 pistons are near impossible to find. Maybe a screamer is better than not riding it . any tricks to make it idle?
24 Oct 2019 03:57 #6
The intake port timing might be very mild to start with. A lot of the Enduro piston ports were. Hop up articles for the piston port Yamaha CT1 and Suzuki TS400 have you make the biggest changes to the intake timing... For example the Don Vesco article has the CT1 intake port lowered 5mm for MX and an additional 2mm taken off the skirt for higher speed scrambles. The Modern Cycle TS400 article has the intake port lowered and the skirt shortened a total of 7.5mm. They say that the midrange was improved tremendously on the Suzuki and the low end was not hurt a bit.
But those are not MR175's! Impossible to know if it would be excessive intake timing without knowing what the port timing is now.
24 Oct 2019 07:28 #7
Don Vesco ! Havnt heard that name in a while. His brother Rick Lives near me and is a friend of mine. I grought the group over to his place In Rock Springs when the Enduro fest was here a few years ago . He Runs the Turbinator land speed car .
Rich
racerclam
24 Oct 2019 07:44 #8
If idle infact does not work you could raise the intake port floor with epoxy the amount necessary , and any where inbetween
Rich
racerclam
24 Oct 2019 07:47 #9
  • coxey2
sounds like its worth the gamble. ebay has the ct1 pistons priced very reasonable compared to wiseco. Im thinking about trying that. t hanks
24 Oct 2019 11:10 #10
