Yamaha CT1 piston swap to a Honda MR
  • coxey2
  • coxey2's Avatar Topic Author
Replied by coxey2 on topic Yamaha CT1 piston swap to a Honda MR
inside the cylinder itself? or on the base (engine cases). will the heat melt the epoxy? thanks
24 Oct 2019 11:13 #11
  • coxey2
where can one find info on how to do it? won't the epoxy melt?
24 Oct 2019 16:48 #12
Replied by RacerClam on topic Yamaha CT1 piston swap to a Honda MR
I use LPS strong steel stick , It will tale 450 degrees . The intake port dont get that hot. I can teach you how to do it , but my business is port work if you wna tme to do it let me know. It has to be accurate .
Rich
racerclam
24 Oct 2019 17:32 #13
  • coxey2
thanks, im gonna try a stock ct1 piston and see what happens. if that does not work, I'll talk to you abut the epoxy. thanks
24 Oct 2019 18:32 #14
Replied by RT325 on topic Yamaha CT1 piston swap to a Honda MR
She'll go good & i've done worse & got away with it. Back i the days of my CT1 ride to work bike in desperation [money--had none] i used a kawasaki 175 piston maybe a kdx if they were around then & had a slight step in the skirt base, step up a little but main problem was a boost port round hole up high under the ringland was about 10 or 12mm or bigger. So i tapped the hole with about two turns of thread & made a bung from a cut off bolt or must've died a bolt to a tight thread, screwed in & cut off, filed it up & worked great. Adapted an MX175 pipe to it & about doubled the pony power. WARNING--DONT"T try any of my stupid tricks & i don't think i'd get away with it again. Won't tell ya any more bad ideas--well not today.
The following user(s) Liked this Post: DaveHunter
24 Oct 2019 19:36 #15
  • coxey2
thanks for the ideas.
25 Oct 2019 15:38 #16
Replied by DaveHunter on topic Yamaha CT1 piston swap to a Honda MR
Hi Mike /
On the Yamaha XS 650 forum there is a ongoing discussion about using JB weld to alter intake ports.
However reading what’s on here so far I’d say install a CT1 piston as / is and see what results. If nothing else it will be interesting .
Don’t go over backwards when that power and hits !!!!
25 Oct 2019 16:01 #17
Band
25 Oct 2019 16:02 #18
JB weld will soften in time plus it dont stay wher you put it , LPS molds and stays where you put it and grinds nicely to finish , trust me it what I do for a living .
Rich
racerclam
25 Oct 2019 16:04 #19
Replied by MarkT on topic Yamaha CT1 piston swap to a Honda MR
Trust Rich if he says the epoxy he uses works, it works.
Devcon makes good "aluminum" epoxy that works in intake ports too.... that's what I've used but was years ago... probably better stuff out there now.
25 Oct 2019 16:10 #20
