77 dt400 running hellaciously...bad
- the_trooper08
Replied by the_trooper08 on topic Re:77 dt400 running hellaciously...bad
Reeds came in. And picked up an idiot proof mixing thingy.
Ordered oil injection blockoff plate.
13 May 2015 13:48
#61
- Bigdog302
Replied by Bigdog302 on topic Re:77 dt400 running hellaciously...bad
don't forget to read the instructions on the Boyesen reeds. there is directions on how to modify the reed cage to improve flow. they will add a bit of noticeable power and improve throttle response.
looks like your bike will do quite well!
Dave
Jesus is Lord!
Dave
Jesus is Lord!
13 May 2015 13:53
#62
- the_trooper08
I noticed the little instruction pamphlet, havent opened it up to take a peek but i sure will! Thanks!
All the repair parts should be here next wednesday from bikebandit.
So hopefully soon i can tear in and get it all done!
13 May 2015 14:10
#63
- Bigdog302
I am looking forward to it too! post pics or videos on it,we love those!
Dave
Jesus is Lord!
Dave
Jesus is Lord!
13 May 2015 15:09
#64
- the_trooper08
Ok so its been over a year and not much has happened.
I have repaired my seat pan and recovered with an old army surplus duffle.
New feont fender and cleaned polished and painted a few bits.
Dug into the crank seals a bit tonight. Found after sitting for a year there is leakage from behind stator.
The 3 screws holding the stator on are slotted. To adjust timing. This is how its sitting now. Ill mark and reinstall in the same spot.
Sent from my SGH-I337M using Tapatalk
22 Jul 2016 22:47
#65
- the_trooper08
Can someone tell me what page timing is on in the repair manual. I need good instructions lol.
Im an automotive mechanic that works on industrial oilfield aplications. This 2 stroke stuff is very different haha
23 Jul 2016 08:18
#66
- Bigdog302
which manual? is it a Clymer's, a factory shop manual or ???? I can find out on the factory manual. this site has the official shop Yamaha shop manual in the tech downloads section.
Dave
Jesus is Lord!
Dave
Jesus is Lord!
24 Jul 2016 06:50
#67
- the_trooper08
The yamaha one off here. Thanks
24 Jul 2016 07:12
#68
- Bigdog302
page 14 under Timing (DT400D) in the first part of the book in maintenance also read the procedure for the DT250 on page 13 for steps 1 through 3.
basically you check and make sure the 3 lines on the flywheel, stator and cases all align at 2.9 mm BTDC.
rotate the crankshaft just almost 3 turns backwards.
Dave
Jesus is Lord!
Dave
Jesus is Lord!
- the_trooper08
Thank you! Doing this tonight!
26 Jul 2016 19:06
#70
