1971 DT1 250 restoration - electrical help!
  • lukeh
  • lukeh's Avatar Topic Author
Hi all, first time posting here.
I recently dragged this DT2 250 (with a 360 motor) out and plan to do a light restoration. First thing is obviously making sure it will run. For that, I believe I need:
- Main switch (where to source?)
- Flywheel
I have the manual and wiring diagram from the files here on the site already.
Any other thoughts or feedback? is this a good first start? I am having trouble sourcing a main switch - any recomendations?
Edit: Looks like I cannot add images either by upload or hotlink. I guess you'll just have to imagine a very sorry looking machine with parts missing, especially the chopped off main switch with bare wires hanging off the frame, and a disconnected magneto with loose wires (but at least they aren't chopped off!).
Flywheel is missing, and I don't know how to test the mageto. It looks like someone tore in to it for an ignition problem, but hard to say for sure.
Last edit: 10 Aug 2026 09:04 by lukeh.
10 Aug 2026 09:00 #1
Replied by pahiker on topic 1971 DT1 250 restoration - electrical help!
Welcome! You can't post pics until you've had 3 posts. You'll need to link via 3rd party like imgur or Google photos. Imgur won't work if you're in the UK unless you come in with a vpn.
1973 Yamaha RT3
2024 Suzuki DR650
10 Aug 2026 09:30 #2
Replied by Enduro nut on topic 1971 DT1 250 restoration - electrical help!
DT2 would be 1972, you're title says DT1 1971? there are differences. Check the vin on the frame and motor and head on over to the tech library/vin numbers to see exactly what you have. Switches are getting harder to find. I may have a few. Flywheel i definitely have some of those laying around. You only need the black wire coming from the stator to the coil to make spark just an FYI.
10 Aug 2026 09:48 #3
