Is it the Boyseen reeds
- mpritch41
Replied by mpritch41 on topic Is it the Boyseen reeds
Thanks...will give the whole electrical system a good one over ...it never sputtered .. just died like I hit the kill switch
sounds more and more like electrical.
09 Jan 2022 15:52
#11
- mpritch41
09 Jan 2022 15:57
#12
Replied by Ht1kid on topic Is it the Boyseen reeds
Yelp that’s what mine did exactly the same (crazy)
09 Jan 2022 16:20
#13
- mpritch41
10 Jan 2022 03:02
#14
- Bigdog302
Replied by Bigdog302 on topic Is it the Boyseen reeds
I currently run Boyesen reeds in my 1975 DT400 and 1979 CR250 and they never had trouble.
The 1979 CR250 recently got hard to start and it is not due to the reeds as a reed valve that is not sealing properly and or chipped reeds can cause hard starting, no problems found there so I am still chasing it.
Dave
Jesus is Lord!
Dave
Jesus is Lord!
10 Jan 2022 07:08
#15
- RT3Sam
Replied by RT3Sam on topic Is it the Boyseen reeds
I agree with condensor!! I had the same issue a couple years back and once I installed a new condersor the bike has ran fine. I also race my RT3 and your issue sounds exactly like what I was dealing with. Quick tip, if you change out the condensor make sure you have a really good soldering iron. If not you won't get the connection soldered in properly.
11 Jan 2022 03:59
#16
- alnarv
Replied by alnarv on topic Is it the Boyseen reeds
A shorting condenser can cause the symptoms described, and they are cheap to replace, but don't rule out the 2 coils. A failing ignition coil can cause the same issue, but a failing source coil is just as likely. When it just begins to fail, it may pass the ohm meter tests, yet not be good. The ohm tests only verify that the internal wiring is not open nor directly shorted, but a break down in the varnish insulation lets the 200-300 volts the coil produces, jump from wire to wire internally. This limits the coils maximum output voltage, but will not be detected in the ohm meter tests. (the ohm meter only puts out a few volts to make a resistance test) The ignition coil can also break down in the same way, but at higher voltage in the secondary.
11 Jan 2022 05:01
#17
- Bartman512
Replied by Bartman512 on topic Is it the Boyseen reeds
I've now swapped out 4 out of my 5 early Yamaha enduros with electronic ignitions from Vape and never looked back. I just got sick of getting broke down with a low or no spark issue with points and condensers, plus I like the brighter voltage for a 12v headlight.
12 Jan 2022 09:50
#18
