JT1 - Two Spring front end conversion?
  • 71-yamahaRob
  • 71-yamahaRob's Avatar Topic Author
JT1 - Two Spring front end conversion? was created by 71-yamahaRob
Hi guys, I am looking to get a set of new forks made for my JT1. I am planning to go with Franks Forks. However, I was considering ordering two tubes made for springs to replace the original that had only 1 tube with a spring. Would this work? I see no reason why it would not. The only thing I can not tell is if the inside of the outer tubes are somehow different and it would not work because of that. If anyone out there has done it please let me know!
Thanks,
Robert
1969 Yamaha L5T
1970 Yamaha L5TA
1971 Yamaha JT1
1976 Yamaha GT80
24 Jun 2025 12:05 #1
Replied by Enduro nut on topic JT1 - Two Spring front end conversion?
I dont see why it wouldnt work. I literally just put mine back together except i bought new GT80 forks that were on ebay because to have the originals re-chromed would have cost doubled for what i just paid. Gt80 forks are only like 3/4" longer. Just thought id throw that info out for you. But i see no reason why having 2 spring type forks wouldnt work.
25 Jun 2025 07:56 #2
  • 71-yamahaRob
Replied by 71-yamahaRob on topic JT1 - Two Spring front end conversion?
Thanks for the GT80 tip good idea for next time. I sent my forks to Franks- they reuse the original collars and will make the new ones both for springs apparently.
1969 Yamaha L5T
1970 Yamaha L5TA
1971 Yamaha JT1
1976 Yamaha GT80
26 Jun 2025 12:26 #3
Replied by Gr8uncleal on topic JT1 - Two Spring front end conversion?
"I sent my forks to Franks- they reuse the original collars and will make the new ones both for springs apparently."
Are they back up and running now?
26 Jun 2025 12:34 #4
  • 71-yamahaRob
Yea they are! I had an hour long conversation with the guy he's great!
1969 Yamaha L5T
1970 Yamaha L5TA
1971 Yamaha JT1
1976 Yamaha GT80
03 Jul 2025 07:24 #5
Thanks for confirming.
03 Jul 2025 08:06 #6
  • JT1 - It’s for the kids...
  • JT1 - It’s for the kids...'s Avatar
Replied by JT1 - It’s for the kids... on topic JT1 - Two Spring front end conversion?
Hi Robert
I read your post with great interest as I’m considering a “2 Spring” conversion on one of my JT1’s as it will be ridden primarily by big kids (adults).
I am curious to know if you were able to use the original JT1 left & right outer fork tubes for your 2 spring conversion?
Were any modifications required?
 I assume you harvested a second spring, washer and spacer from a donor JT1(2)?   Please confirm.
Can you offer any insight into the pros/cons of using JT1 inner fork tubes versus using GT80 inner fork tubes?
I understand the GT80 tubes are a bit longer.
Did you encounter any other gotchas along the way?
I would appreciate any insight you can offer into these questions.
Regards,
Steve in SW Michigan
04 Sep 2026 11:05 #7
Moderators: yamadmin, Makotosun, DEET, Vinnie, Mini Enduro Man, James Hart
