Torque Settings
  • hatrick1960
  • hatrick1960's Avatar Topic Author
Torque Settings was created by hatrick1960
Hi
Could someone please confirm what the torque settings are for the six cylinder head studs and the four barrel studs on a DT400 1976.
Many thanks
14 Mar 2021 10:08 #1
Replied by Gr8uncleal on topic Torque Settings
If no-one comes back with specifics, have a look to see if there is a Service Manual in the Tech Library here. If there is, the info might well be in there.
14 Mar 2021 10:41 #2
Replied by RT325 on topic Torque Settings
I'll take a guess but dont take it as gospel. *mm head studs 15ftlb's & 10mm base studs 25ftlbs & to be honest i have a habit of overtightening everything & don't use a torque wrench [it got stolen in about 1985 when one of the kids had dodgy mates--good W&B model too].
14 Mar 2021 14:55 #3
Here's a shot from the page in the service manual from a "78 250--400
14 Mar 2021 15:03 #4
Not that clear but my computer skills are lacking--took a screen shot. Not tried that before lol. Just hit it & comes up a bit. Here's the manual to download.
www.yamaha-enduros.com/index.php/service...34-1978-dt250-dt400e
Last edit: 14 Mar 2021 15:07 by RT325.
14 Mar 2021 15:06 #5
  • hatrick1960
Replied by hatrick1960 on topic Torque Settings
Nope, nothing there!
15 Mar 2021 00:35 #6
Appears to be on page 6 of the manual (and maybe elsewhere in there as well) - see link.
Vintage Yamaha Enduro Fans - 75 DT250-DT400 Factory Service Manual (yamaha-enduros.com)
15 Mar 2021 00:58 #7
It’s the first & third item on the pic I put up. Says cylinder head nut on first line then cylinder nut on third line. Not sure why they then say bolt though below that as is nuts in both cases. Doing this on my phone so hope i’m on the same page or planet.
15 Mar 2021 01:16 #8
Replied by Wessi on topic Torque Settings
Zylinder head nuts torque in the manual says 2.1 -2. 5m/Kg
That´s 21 - 25 N/m.
Regards from Germany
15 Mar 2021 01:27 #9
Replied by MarkT on topic Torque Settings
You need to read through the service manual...  Yamaha often puts the specs within the text...  a quick browse of the manual in the tech library (1975, but basically the same) shows head torque at the beginning in the maintenance section.  Then they show the head and cylinder torque in the "engine assembly" section...  and then finally, near the rear of the manual in the Appendices there is a chart of specific torque settings, page 143.
To convert m-kg to N-m multiply by 9.8
15 Mar 2021 05:39 #10
