Sneezles and a RT2..
- Sneezles61
Replied by Sneezles61 on topic Sneezles and a RT2..
I did file diagonal slots into the pads as directed from my Clymers manual….
I have inquired to KDI for the rubber grommets for both fenders on my bike… they don’t have them at this time… Well, HVCcycles does but lists only the back ones…
Since I didn’t do them at the same time, I really think they are about the same… I’ve asked them and await their reply…
I better go look at the Yamaha pages to verify also…
A few details to finish up and I’ll be doing way more riding and alot less tinkering!
Sneezles61
Sneezles61
18 Jul 2022 14:38
#71
- Tom P
Replied by Tom P on topic Sneezles and a RT2..
My 50-year old brake shoes were glazed, but still completely intact and bonded. I did replace them both, and the set I got for the front have water grooves.
18 Jul 2022 14:54
#72
Replied by Ht1kid on topic Sneezles and a RT2..
Sneezles61 if you are talking about the fender rubbers etc Motodad24 has them on eBay
18 Jul 2022 15:54
#73
- Sneezles61
Well I didn’t look for the brake shoes option…. Maybe ifn they said something about ice I would’ve noticed…..
I’ll look at motodad…
I did look at the Yamaha stuff… both front and back grommets share the same part number…
Stuff sinks in slowly on my side..
Sneezles61
Sneezles61
18 Jul 2022 19:22
#74
- AirborneSilva
Replied by AirborneSilva on topic Sneezles and a RT2..
For my DT2 front and rear fenders I picked the best grommet out of the ones I took off, went to Ace Hardware and got grommets that were close, not quite as thick so I couldn't use the collars but I'm not building a concourse restoration so for me that didn't matter but was considerably cheaper...
19 Jul 2022 02:25
#75
- Sneezles61
Mine is not a planned show pony also… I’ll head to our local Ace today.. thank you for the heads up,
Sneezles61
Sneezles61
19 Jul 2022 04:28
#76
- AirborneSilva
You're welcome, can't see paying 4 times as much (or more), for a darn rubber grommet. Lowes has them as well but I've found that Ace has a better selection.
19 Jul 2022 06:34
#77
- Sneezles61
Well… I’ll be replacing my clutch cable… it’ll be here next week. It has a nasty kink and I believe it’s really stretching the cable and not fully disengaging the clutch…
I looks as though it has been routed down the left side clock, tucked under the hull of the fuel tank, above the rubber tank bumper then onto it’s appointed spot…
I don’t believe that’s correct.. This bike only has 3900 miles on it… I don’t feel the need to start looking at the clutch assembly just yet… Could any of you clarify the cable routing? I would be very thankful!
Sneezles61
Sneezles61
04 Aug 2022 13:32
#78
- Sneezles61
It’s raining here today. Replacing the clutch cable… my how that cover is caked in dirt… I find that the cover has been welded. Sure seems fine so I won’t worry about looking for a cover. And I took the actuator apart to clean the grime… and as many of you have found, it’s in need of replacing. I’ll head over to KDI and get one coming.
I’m not in any big rush to get the old grey mule out of the garage. It’ll take what it takes and every part I find bad back to good order.. It’s plain old fun tinkering with it.
Sneezles61
Sneezles61
The following user(s) Liked this Post: MarkT, AirborneSilva
12 Aug 2022 08:59
#79
- AirborneSilva
You have more patience than I do. It's been over a month since I've been able to ride my DT2, the top end is getting some work done on it and a new carb, can't wait to get it back. Been busy dong odds and ends on it, cleaned and painted the replacement oil tank, original has cracks around the mounts and was leaking.
I put one of those KDI repalcement parts on my acuator, works great. Installing it wasn't too bad, used a friends vice and moved it a little at a time, also used some spray lubricant to help it along.
12 Aug 2022 09:51
#80
