CT2
- Schu
Replied by Schu on topic CT2
I don't understand your use of a syringe. I use an empty bottle from motor oil with a spout style filler cap like you get on a bottle of 90 weight gear oil. Then I push the fuel line onto the spout and connect it to the carb fitting. I added a hose clamp on the spout after my line slipped off one time......
03 Apr 2021 07:52
#11
- dwil4
Replied by dwil4 on topic CT2
Yea I once had a setup like that but it's no longer. I am just filling a syringe and squirting fuel in the line till the bowl is full. A full carb should run a minute or so but this runs a few seconds and dies. Its like if I put enough gas in the carb it doesnt have a choice but to suck a little in the cylinder. I know it sounds just like a stopped up carb issue but I can blow compressed air and carb cleaner through every passage. Coukd they motor be sucking so much air that it simply doesn't have the fuel to even out the ratio? Hell idk I'm just spit balling..Lol
- dwil4
Come on experts spit out some thoughts for me.. I'm at a stand still here. I would be willing to send my carb to one of you if you would try it on yours just to rule out a bad carb????? Haha
03 Apr 2021 18:45
#13
- darinm
Replied by darinm on topic CT2
If you really want to I could throw it on mine to test. Worth getting the float bowl gasket and making sure the float height is correct before sending it off though.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2009 BMW X-Country 650
2013 Yamaha XT250
2020 Zero DSR
1997 BMW R1100R
2013 Yamaha XT250
2020 Zero DSR
03 Apr 2021 20:48
#14
- dwil4
Do you know the float height?
03 Apr 2021 20:52
#15
- darinm
Page 81 in the manual; www.yamaha-enduros.com/index.php/service...-and-parts-catalogue
1972 Yamaha CT2 175
1997 BMW R1100R
2013 Yamaha XT250
2020 Zero DSR
1997 BMW R1100R
2013 Yamaha XT250
2020 Zero DSR
04 Apr 2021 07:38
#16
- dwil4
Got it running..
05 Apr 2021 20:51
#17
- Mothersbaugh
Replied by Mothersbaugh on topic CT2
Bravo.
05 Apr 2021 20:57
#18
- bradocross
Replied by bradocross on topic CT2
Hurray
06 Apr 2021 18:03
#19
- Schu
WooHoo!
06 Apr 2021 18:14
#20
