DT2 and DT3 headlights
  • Doctor K
  • Doctor K's Avatar Topic Author
DT2 and DT3 headlights was created by Doctor K
Anyone out there know of either OEM or other replacement sealed beam headlights for the 1972-1973 DT/RT?
30 Jun 2026 09:11 #1
Replied by Gr8uncleal on topic DT2 and DT3 headlights
I'd go for one of the aftermarket headlights with the replacement bulb facility, although you might need to change the wiring pigtail.
The original DT1 headlight did, in fact, come with an APF bulb which could be replaced, and these do turn up occasionally.
30 Jun 2026 09:40 #2
Replied by DVM on topic DT2 and DT3 headlights
In the past I have obtained 5 3/4" headlight lens that fitted H4 bulbs from Octane Lighting. I believe they also sell 35/35 watt H4 bulbs. The headlight lens can be fitted into the headlight ring with "W" clips.
30 Jun 2026 11:02 #3
Replied by Enduro nut on topic DT2 and DT3 headlights
NAPA 4020. Double check the voltage and dimensions before you buy it. Its been a bit since ive had to buy one.
The following user(s) Liked this Post: goatboy56
05 Jul 2026 13:50 #4
