AT1C Autolube white priming wheel does not turn
- tennbamaman
Replied by tennbamaman on topic AT1C Autolube white priming wheel does not turn
For sure this is a great site. Folks offer assistance and they know their stuff. Helped me get my 1971 AT1C running good. I got my side cover in. Not that i needed the cover but it had an oil pump on it. I got it so cheap, i had to chance it. For the first time ever, I actually got to take my finger and turn the the thin white priming wheel, lol. Without this site, i would not even have known it was supposed to turn. Thanks to all
11 Jun 2021 20:13
#31
- Sneezles61
Replied by Sneezles61 on topic AT1C Autolube white priming wheel does not turn
Older ct90.. nice bike..
Crazy.. the first car I bought was a 62 VW... Rag sun top.. I didn't know shinola back then... 74'-ish?.. It just kept running.. Some "older peeps" I knew bought it... I made a couple bucks.. that was only once..
Sneezles61
Sneezles61
12 Jun 2021 19:37
#32
- msavitt
Replied by msavitt on topic AT1C Autolube white priming wheel does not turn
The CT is a ‘68 and fairly clean and is really fun at 45
the VW is a ‘71 super beetle with a 2110 that really nice to drive
The following user(s) Liked this Post: Makotosun, MarkT, Sneezles61
12 Jun 2021 22:31
#33
- tennbamaman
It appears i might have gotten lucky. The pump i got with that cheap side cover appears to work properly. I have an extra side cover, lol. I had to replace the throttle recoil spring as it was rusty and broke. I used the one and the shims off my old one. I still need to test to make sure its pumping the proper amounts. For sure, im still running premix and its for sure getting some extra oil. Update on the other one is that i still have not got the shaft freed up but i have not removed the rubber seal yet. The old used one i got in was the priority. I will pull that seal on the other one to see if that helps me get the shaft out. See the link
old used pump
old used pump
14 Jun 2021 09:37
#34
- tss118
Replied by tss118 on topic AT1C Autolube white priming wheel does not turn
New member, just came across this resource and the forum is fantastic.
I acquired a 1971 L5T-A TrailMaster. Previous barn bike that a gentleman up the road got to running condition, but didn't have the heart to take it any further. it was running well, but he was premixing as well as running the autolube pump as he did not trust the pump.
When I dug into it, the pump was leaking quite badly and leaving a mess of 2 stroke oil where ever the bike ended up. I pulled the pump and disassembled. It looked like someone else had been in there as gasket had been gooped up with liquid gaskets etc.
I ran it through the ultrasonic, got it looking good and picked up the HVC seal kit. I rebuilt the pump (even managing to place the small springs and pins many times successfully), but when I snugged the plinger/worm gear into the body, the piston could still move up and down, but the worm gear became very very tight and you could not rotate things with the starter wheel. Back off the screws on the body, and things are good.
I ended up disassembling/reassembling more times than I would like to admit trying to figure out what this happens, and in the process I think I have damaged something as the big shaft that goes through the body no longer goes in smoothly and it feels like I have steel on aluminum binding.
Long story short, after reading through this fantastic resource, the answer appears to be DEET...
1971 L5T-A Trailmaster
21 Jul 2021 08:50
#35
Replied by Gr8uncleal on topic AT1C Autolube white priming wheel does not turn
Yes, DEET is a great resource for pump repairs (as well as many other things!).
21 Jul 2021 09:47
#36
- Mothersbaugh
Replied by Mothersbaugh on topic AT1C Autolube white priming wheel does not turn
"Long story short, after reading through this fantastic resource, the answer appears to be DEET..."
Best thing about DEET is that even though you may have screwed things up, he'll figure out what you did and let you know in a kindly fashion what that was and how to avoid it in the future. I once told him he is a great teacher, better than most I met in my own 28 years of teaching in the public schools. But I'll bet he's never had a formal education course in his life. He was just born that way.
21 Jul 2021 14:18
#37
- DEET
- Moderator
Replied by DEET on topic AT1C Autolube white priming wheel does not turn
"But I'll bet he's never had a formal education course in his life."
Well, I have a good excuse....
I was abducted by aliens as an infant.
They brought me back in 1968 along with a white motorcycle.
The following user(s) Liked this Post: Rick C., MarkT, 2fishkev, Bigdog302, swm, JGersh, Schu
